Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-20-2004, 10:33 PM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
Annoying screech
Yo guys having a big embarassing problem here. Okay so every time i turn my car on this loud ass shreaking screaching sound happens, and its most likely the belts. I learned to deal with it because it only happened when i start the car up. However, just this week i started the car up it made that same exact sound, but it also made it when i started to turb the steering wheel a bit as i pull ot of my parking spot. And as i turn the corner out pof the parking lot (left or right) it makes the sound when i let off the clutch a little and put on the gas while im turning. So im thinking i need to tighten the belts....if you disagree let me know. I doubt if its the timing belt, it may be the other ones. Anyway, i never personally changed or messed with belts at all, so can someone let me know how go about fixing this problem. Thanks in andvance guys! -Ray
99 GST/evo 3 16g/3" Catback/Intake w/filter/UICP/1g BOV/Complete prothane motor mount inserts/Boost gauge/AF ratio gauge/MBC/NGK Plugs/HotWires/17" Sport edition fox 5 racing rims w/Fuzion tires
One retarded ass site! Geeeeeeeee
My Car
[url=http://www.myspace.com/nobledsm[/URL]
Old 11-21-2004, 01:16 AM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: Annoying screech
I had a similar experience... my AC belt was dragging on the AC side and the motor pulley burned right through the belt!!! Lot's of white smoke under the hood!!!!! Quite shocking/funny!! Yes look at tightening your belts..alt. belt and steering belt... should only be able to turn/twist the belt about 90 degrees
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 11-21-2004, 08:27 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
it sounds like its your power steering belt. im not sure where the adjustment is on 2g's but it should be pretty simple
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-14-2004, 08:46 PM
tsi9187 tsi9187 is offline
got the same problem with my car but it only happens when my car is cold and i start it....i know its the belts im just to lazy to fix it...plus people always think its funny cuz it sounds like i got a piece of poop car...not sayin that after we race
