Old 11-20-2004, 09:57 PM
lionelkirk2004 lionelkirk2004 is offline
Send a message via Yahoo to lionelkirk2004
1995 Blazer, What Value?
I test drove this 1995 Blazer 4 Door 4X4. There were alot of things wrong with it. One, it didn't start right away. Two, the tires are really wore out. Three, the turn signals didn't work. Four, the service engine soon light was on. Now I need to know what I should offer. They have the price a $3600, But I ain't payin that much for a SUV with that many probs. Please respond ASAP. Thanks.
Or Email me at: [email protected]
Old 11-20-2004, 10:05 PM
BlazerLS BlazerLS is offline
Re: 1995 Blazer, What Value?
The check engine light is probably caused by oxygen sensor or indicating a misfire. My guess $500. The turn signals is probably the multifunction switch approx. $350.
Old 11-20-2004, 10:09 PM
Re: Re: 1995 Blazer, What Value?
What is an oxygen sensor and could you tell me about the misfire stuff. Is that stuff something major?
Old 11-21-2004, 12:38 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Hold on!
BlazerLS, don't start this guy on a wild goose chase, the Check engine light could mean over 200-300 things. Saying it is a O2 sensor is just stupid. If you don't know, don't post. This forum is here to help, not confuse him.
lionel,
The CPI injector is shot in the upper part of the engine, that will cost about $300-$500 if you do it yourself and that will cause the extended hard starting and poor idle and drivablility. This will probably have caused the EGR valve to get clogged full of carbon which will also need to be cleaned.
And that is just to start.
That truck the way it stands is worth maybe $2000-$2500 max seeing you will have to invest a lot to get it back to normal.
My suggestion is to keep looking.
I own a 1995 and I like it but I wouldn't have bought it if it was in that bad of shape.
Good Luck.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-21-2004, 10:38 AM
Could you help explain how I would go about fixing the CRI injector? And where I could get one?
Old 11-21-2004, 01:52 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
"CPI" injector....Remove the upper plenum, pull each poppet nozzl, pull the injector, put in reverse, torque the plenum bolts down to 8 ft pounds each.
Old 11-21-2004, 03:29 PM
What does CPI Stand For?
Old 11-21-2004, 05:51 PM
BlazerLT's Avatar
AF -Advisor
CPI = Center Point Injection System
Here is my experience with the repair.
http://www.s10forum.com/forum/showth...pi+replacement
