Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 11-20-2004, 08:38 PM
rendertrust's Avatar
rendertrust rendertrust is offline
i need new rotors
well i here a sound like metal grinding metal after every revolution of the tire, im pretty damn sure its a rotor, those things are pricy anybody know where i can get one cheap for a 1990 300zx N/A
Old 11-21-2004, 12:12 AM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
Re: i need new rotors
this is a great deal, wish i would of found it when i was buying new rotors. for $450, you get front AND rear slotted/drilled rotors, front AND rear pads, stainless steel brake lines, and brake fluid. if we buy all that stuff seperate, it would be about $650-$700. here is the link, http://conceptzperformance.com/Cart/...569.76.137.188
-Jared
ZedEx Crew Member #2
Old 11-21-2004, 12:45 AM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
dude...you dont even have to worry about it. metal on metal isnt your rotor. its your brake pads. if you drive to long with the metal sound then you might need a new rotor but i doubt it. go to auto-zone, $20 for new brake pads for the front. if you need the back, it wil probably be a little cheaper than the $20. (i have bigger pads on my bicycle than i do the back of me Z).
after that, your gonna need some brake lube and some of that "no squeak" stuff. total, i spent like $23 for the front brake pads.
then beings your hearing metal on metal. take some medium course sand paper and sand down the rough part of the rotor. you should be able to tell by rubbing your fingers across it. if you need help installing them just PM me or ask away. i just installed all 4 on my 90' a couple weeks ago. good luck...
ZedEx Crew Member #4
Old 11-21-2004, 01:13 PM
well i also believe its the rotor because the car wobbles from side to side, but i also need a new rim because one is fractured
Old 11-21-2004, 03:48 PM
Z Cars Fanatic
wobbles from side to side?...thats more than a rotor, you mean the steering wheel shakes when braking??? yeah, you may need new rotors then, but the metal to metal sound just means you need new brake pads. that brake set that freak gave you is a great deal...but if you look on ebay you can get it even cheaper than that. good luck...
Old 11-21-2004, 04:55 PM
but on ebay, they probably aren't as good quality, therefore they could crack or something. you get what you pay for. where is your wheel fractured at?
-Jared
Old 11-21-2004, 05:24 PM
Z Cars Fanatic
maybe they are, maybe they arent. they are only like $50 cheaper so who knows.
Old 11-23-2004, 01:31 AM
Hodo Hodo is offline
Napa you can get cheap OEM replacement rotors, for about 60-100 bucks I cant remember I just did mine about 45 days ago.
Old 11-23-2004, 01:33 AM
Z Cars Fanatic
all 4 or just 1??? if thats all 4, just take them 2 a machine shop and have them machine you some slotted rotors, s***.
Old 11-23-2004, 01:53 AM
Just the front 2 rotors and pads with shims. And one retaining spring........ damn pot holes.
Old 11-23-2004, 02:17 AM
Z Cars Fanatic
yeah i think i got a bend on the inside of one of my wheels from a pothole. im thinking about taking it up with the city.
but still thats not bad...so without pads. probably $50-70. i might have to look into that, machine shops can make slotted rotors right. im just assuming that is basically how they make slotted rotors, right?
Old 11-23-2004, 02:19 AM
they can but buy a quality brand rotor first, other wise they may crack or warp.
Old 11-23-2004, 02:20 AM
Z Cars Fanatic
i see...i will probably just end purchasing a full-kit from CZP when ig et around to it.
Old 11-23-2004, 02:24 AM
That would be wisest..... I am still up in the air about my brakes.... dont know yet, might go with a UK firm or stay asian/domestic.
Old 11-23-2004, 02:30 AM
Z Cars Fanatic
how hard you think it would be to custom make your own big brake kit??? i always thought about it. like seriously the only hard part would be getting the caliper remounted, right? im not saying that i can do this with a standard hammer and sockets but im sure it could be done, of you went to the drawing board and designed a new bracket and then go to the metal shopa nd buy yourself a hunk of iron and take it to a machine shop and have them make your blueprint come to life. ehh...maybe im just dreaming. probably end up costing just as much as Z1's big brake kit, anyways. but it would be pretty cool to say i designed my own big brake kit.
