Old 11-20-2004, 04:28 PM
explorerfriendly explorerfriendly is offline
Question whinning sound while running and cracking
any one know why my 87 cherokee's I6 engine is whinning? it happends all the time and is very very slight but annoying. It also sounds like a diesel when going up hills or under fairly hard acceleration. i was thinking that the exhas manifold might have somthing to do with the whinning after reading other threads but any way to check that, or is there anything else that could be making that noise?
thanks,
nick
87 cherokee
I6/5spd.
255,000 miles
Old 11-20-2004, 05:22 PM
scuba4321's Avatar
scuba4321 scuba4321 is offline
the diesel sound is engine knock, ping, try the next higer grade gas. check your knock sensors too. the winning could be your alt, water pump..hard to tell someone without looking and listening
Old 11-21-2004, 09:18 AM
Saudade's Avatar
Saudade Saudade is offline
Re: whinning sound while running and cracking
As Scuba says, the whinning may be from a failing bearing from one of the sources he mentions. Does the whining change with engine speed? Does it get worse/better when cold or hot? Check the tension on your belt.
Old 11-21-2004, 09:55 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
In addition to the above, power steering pumps can also whine, especially if the fluid is low, or if they have become worn or damaged internally.
Old 11-21-2004, 08:54 PM
Re: Re: whinning sound while running and cracking
The whinning stays the same all the time and dont no if it will whine in the heat, just started during the winter days. im taking it in to my mechanic to get some other problems fixed and i will ask him then. thanks soo much for all ur help guys!!
87 cherokee
I6/5spd.
255,000 miles
