Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 11-20-2004, 04:28 PM
MWILKY MWILKY is offline
95 318 startup problems
hello,
new to the site but have problem need help with. 1995 ram 318 hard start, when it does start the engine hesitates when accelerator is depressed. will idle roughly until reaching operating temperature, at which time every thing runs great. replaced the fuel pump on advice of mechanic but did not correct. any ideas out there.
Old 11-20-2004, 05:50 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: 95 318 startup problems
The idle air control valve is bad.
My Mopars
Old 11-20-2004, 06:32 PM
LTJGWorth's Avatar
LTJGWorth LTJGWorth is offline
Yea, probably the IAC valve. Maybe the TPS, but probably the IAC because it runs normal after it's warmed up.
Old 11-21-2004, 06:51 PM
Thanks For The Advice, Something Told Me To Check The Coolant Temperature Sensor Before Buying The Iac. Looks Like The Cheaper Part Was The Fix. That Never Seems To Happen To Me. We Will See Over The Next Few Days. Again I Wish To Thank You Guys For The Input.
