Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 11-20-2004, 04:19 PM
ssigurdson ssigurdson is offline
glow plug light is blinking
hey i just got a 00 jetta tdi. i was driving home and the glow plug light started blinking. im gonna take it into a dealer but dont wanna get scammed can someone give me some advice so i have some idea what im talking about when i go to vw. thanks
Old 11-21-2004, 03:50 PM
boschmann boschmann is offline
Re: glow plug light is blinking
I believe that is an indicator to drain the water seperator in the fuel filter.
Old 11-21-2004, 10:26 PM
so does that mean i have to replace the fuel fiter or is there a way to drain it?
Old 11-22-2004, 08:25 PM
elmo4069 elmo4069 is offline
If your glow plug light is blinking this usually indicates a brake light is out or the brake light switch is faulty - The brake light switch was recalled so be sure to verify its operation
Old 11-23-2004, 08:42 PM
I believe the drain valve is on the bottom. It used to be a large white knob that you would turn to open, I can't remember if that kept up to your year. If not post back & I'll look it up.
Old 11-24-2004, 03:03 PM
Doug Tatham Doug Tatham is offline
Cool Re: Re: glow plug light is blinking
If you check your owners manual it explains how to drain the water separator in detail. There should be a bag that connects to the separator in your trunk in case you have to drain it in an emergency.
Attached to the underside your car on the passenger side just forward of the rear tire is a white plastic box that has a valve handle. put a pan beneath it and open the valve. When fuel comes out stop. Keep your face (eyes) clear!
Doug
Old 11-28-2004, 03:19 PM
I'm pretty sure they dropped the water seperator under the car with the A3 models.
