Old 11-20-2004, 02:45 PM
boosz28 boosz28 is offline
4 barrel carborater broken?
I have a 1984 z28 and i jus replaced the engine. I put a 350 in it and used the same carborater that was on the 305 that was originally in it. I wanted to know what i should do because my quad flap isnt opening and when i push on the gas sometimes it feels like somethings braking and no gas gets to the engine then it kicks back up again( gas is getting back in the engine)
Old 12-28-2004, 09:54 AM
supervisor1886's Avatar
supervisor1886 supervisor1886 is offline
Banned
u should go and find a nice used Qjet from somebody or even a junkyard and properly tune it. And get rid of that piece of shit. it is worthless and will give problems even if u fixed the carb. That is why we call em "QuadroBogs"
Old 12-28-2004, 05:32 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
Re: 4 barrel carborater broken?
get you a holley 650 cfm.
Old 12-28-2004, 05:40 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
edlebrock makes some pretty good carbs... 600-650cfm would be a good size for a 350...
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 12-28-2004, 05:43 PM
my brother has a 650 edlebrock and its garbage. the car has a brand new engine under the hood and the carb is bringing her down, we slapped a 650 holley on it that was on my dads 86 blazer and it ran perfect. we have tried rebuilding the E""""""" and new jets and everything and i believe that its just junk from the start. (probally slapped together on a friday)
Old 12-28-2004, 06:20 PM
Banned
if u want a really bad gas mileage go with edelbrock. Original Qjets are much nice and more efficient when properly rebuilt
Old 12-28-2004, 06:25 PM
Re: Re: 4 barrel carborater broken?
see another pissed edelbrock! would you like to know were your gas goes????? out your tail pipes, thats how bad it floods my brothers car out. when you go to wal mart or some where and cut it off and go in for a while. you have to hold the gas wide open to get it to start cause its flooded, once we shot 2 fire balls out the back.
edit* if you have a race car a edelbrock would be fine, but not for everyday use
Old 12-28-2004, 11:36 PM
black84z28 black84z28 is offline
the reason your carb runs like crap is it was the cc qjet..you running the same distributer?...has it ever been rebuilt?...
if an edelbrock is set up correctly...it wont give you any trouble...carb + gas milage?....kidding me?...
i ran a 1406 edelbrock on my 305, not only did it run alot of mid-low 14 sec times...it was a really good carb...
for a race car...you'd go holley...its more tunable
Old 12-29-2004, 02:12 PM
CORE402's Avatar
CORE402 CORE402 is offline
All three carbs are excellent carbs. Quadrajets and Edelbrock carbs are very efficient, gas mileage etc, with there use of metering rods. However for racing you can't beat the holley type for ease of tuning and variety. If this is for pure street or street strip go with the edelbrock or the Q-jet.
More towards the original question. What exactly is the carb doing? I dont understand your explanation. I assume the quad flap is the air valve secondary. How do you know it is not opening? If you are just stepping on the gas when the car is out of gear the air valve will not open. The air valve only opens at full throttle under load, meaning only while the car is in drive/gear.
1973 Camaro
AFR 195cc heads
CNC Motorsports 383 short block
Comp Cams hyd flat tappet
TH350
Dual 3" exhaust (LOUD)
Corporate 10 bolt w/ all new internals and axles
Old 12-29-2004, 07:35 PM
Banned
The secondaries arent supossed to open when the engine is cold. And its controlled by ur choke. There is a lockout pin for it. That noise you were talking about is nothing more than a plunger noise- it is all normal and you have internal problems with the carb which sometimes are hard to catch.
About Edelbrock: Edelbrock actually produces Qlets and you can by em or buy parts to tune or upgrate your original GM Qjet.
Once againt dont messe with your carb get a good used Qjet unless its just simple problems such crapy gasckets or dirt.
About carbs:there are street carbs like Holley double pumper or one of the more serious Edelbrocks which suite only hardcore engines with lots of hp. Putting one of those on your car will fuck the gas mileage up- too much gas.
Old 12-29-2004, 07:38 PM
Banned
about the flap. This is vacuum conrolled and opens when engine needs extra enrichment or under really heavy load. It is the part that actually gives all the perfomance comparing to 2 bbls.
Old 12-29-2004, 08:17 PM
about a week ago itook the carb off and went and got a rebuild kit.....i got everything done( rebuilt it) except i havent done the choke yet...i still have to adjust that ....i'll let you guys know what happends when i put it back on the car...
.........I doint know wut everybody says about its hard to rebuild a qjet...i thought it was very simple, just time consuming
Old 12-30-2004, 12:18 AM
CORE402's Avatar
They are just more complicated then the others. Fixing what you have is the least expensive and you will learn about them along the way. Aftermarkey Qjets are perhaps the most expensive carbs out there. Just do what you want to do.
1973 Camaro
AFR 195cc heads
TH350
