Old 11-20-2004, 01:58 PM
Joe_Cool97 Joe_Cool97 is offline
Need help from you guys FAST!
Hey .. I've got a leak in my fuel line under the car.
Now what I need to know is if I can use rubber hose to patch the leak. I've heard that under the car you have to have steel fuel lines for it to pass a safety. Can someone please tell me.
thanks
Old 11-20-2004, 04:21 PM
dwalmop dwalmop is offline
Re: Need help from you guys FAST!
you can use rubber and some hose clamps, but I would only do it temporarily until you get real lines.
Old 11-20-2004, 05:18 PM
KustmAce's Avatar
KustmAce KustmAce is offline
Grande Boleros de Fuego
That'll be a quick fix till you can properly repair it. The gas will corrode the rubber.
MAKE ART, NOT WAR
Old 11-20-2004, 07:00 PM
public's Avatar
public public is offline
DO NOT USE REGULAR FUEL LINE. Your info shows you have a 94 Cavi. This is a fuel injected car which run in excess of 40 psi in the fuel system. Regular fuel line is only rated for 7 psi. Make sure to get hose rated for a fuel injection system and then this is a permant repair. Just as safe as the RUBBER section that comes from the factory that connects to the engine.
As for Gas corroding the rubber??? Where did anyone hear that? What is that hose at the gas pump made of ? Not to mention the section on the end of your factory metal lines that connect to the motor. Was there some question that he/she might use aquarium tubing or something?
Yes, I am retarded.
Old 11-20-2004, 07:37 PM
godenm's Avatar
godenm godenm is offline
yeah, i agree with public,you can get 100psi fuel hose for cheap,double clamp it, make sure theres no kinks or moving parts & it will probably last as long as the metal lines
Old 11-21-2004, 02:55 AM
Mangoamerican Mangoamerican is offline
Send a message via ICQ to Mangoamerican Send a message via Yahoo to Mangoamerican
i just replaced a part of my fuel line with efi rubber tubing (they have really neat clamps made esspecially for them) works great!
