Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-20-2004, 01:36 PM
babyxxboy86 babyxxboy86 is offline
Send a message via AIM to babyxxboy86
Question maxing out an eclipse
i have a 1996 eclipse that is an auto. i want to make it a standard. first off is that possible ? my second thing is that i am going to be in a car club and i need to increase the performance of my car i already have an intake in it and a full exhaust but what else can i do?
Old 11-20-2004, 02:47 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: maxing out an eclipse
we need more detaile about the car...
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 11-20-2004, 04:19 PM
so what else do you need to know bout it. its 2.0 engine 16 valve 4 cylinder. what else?
Old 11-20-2004, 11:55 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
there's a turbo, and a non turbo. if you need more than a few more horsepower, you are looking at a turbo kit, or getting a real car, such as a GSX/GST/TSI.
If you don't know if it's possible to do a manual tranny swap, then you either have to A. pay a shop $6000 or not do it.
Old 11-23-2004, 04:48 AM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
you know, to be honest man i wouldn't even ask about your non turbo on here cuz all they will say is that you should buy a turbo like they have,thats all they ever say,some guys will help you but most willl brush you off,cuz i have a n/a also and if you noticed i stoped making threads awile ago cuz that is all they say
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 11-23-2004, 12:21 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: Re: maxing out an eclipse
The reasoning behind that is the fact that the 420a bang for the buck ratio is NOTHING like the 4g63. You COULD turbo your 2g N/A, but that's spending lots of money just to get to where a mildly modified 4g63 is. Everyone recommends just selling the car because it's just not worth the trouble (unless you have deep pockets).
However, for a nice boost that doesn't cost TOO much, nitrous is a wonderful thing. A friend here has a 75 shot on his 2g N/A, and I must say it pulls pretty hard for what it is. Every now and then he'll throw in the nozzles for a 95 shot just for kicks, and boy that is fun .
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 11-23-2004, 05:02 PM
BOSTONjoe98gs
i guess your righti know like everyone else that a 420a wont keep up with a gsx unless you get like a hahn stage 2 or something which i could never afford,but me i just did the basics and its fine with me its not like i go to new hampshire and race or anything but i like the body of my car and the sexyness of it so that alone is why i like mine turbo or not,peace
ubend delete
3in jimmyC downpipe
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
Old 11-23-2004, 10:08 PM
I-Eat-Civics I-Eat-Civics is offline
Send a message via AIM to I-Eat-Civics Send a message via MSN to I-Eat-Civics Send a message via Yahoo to I-Eat-Civics
Well what you can do is:
Performance Header
Hi Flow Cat
Short Shifter
MSD ignition
just look around on nopi (www.nopi.com
If turbod:
low compression engine components
BIgger Turbo
louder blow off valve
The 91 LS no Longer Lives www.RIP91TEG.piczo.com
__________________________________________________ ___________
1995 Acura Integra GS-R:
Blown Motor Waiting for swap
Old 11-23-2004, 10:13 PM
97_3clipse's Avatar
Originally Posted by I-Eat-Civics
If turbod:
BIgger Turbo
LMAO!
Old 11-25-2004, 05:14 AM
Talon_ESi Talon_ESi is offline
Send a message via AIM to Talon_ESi Send a message via MSN to Talon_ESi
There is nothing wrong with owning a N/T there are so many parts for it and they are not all super expensive. You just have to look around for the best deals and take advantage of the companies that do price matches. One of my cars is an N/T and I threw a rod in it, now I am going to put a NEON block in it 420a, but since I need a new motor I am going to bore it out probably .030" over with Eagle forged H series rods and forged racing pistons from JE with 8:8.1 compression, new lifers, 1mm+valves intake/exhaust, crane stage 2 cams and +/-12*gears, 3rd gen lifters for a 4g63, underdrive the accessories, cold-air intake, Venom intake manifold HKS Hyper cat-back exhaust,GReddy headers port and polish, 5 angle valve job, racing plugs/wires, Billit aluminum pulleys on all accessories, Billit alumenum flywheel, Hein 600cc injectors, intake resistor, and an ECU mod-chip. This ran around $2,000(this is only because I am doing most all of the work on my own) on a $2,500 car, so its like a heavy moded car for $4,500, and you could say it has 0 miles on it this brings overall HP up to 300+ on what started as <150HP torque falls just over that at 300+ ft/lbs and started as <140. I want to get the Hahn racecraft turbo kit it costs about $7,000-8,000, but it is so worth it, the power it would have with that is unreal we are talking like 700+ at 18 p.s.i. but I don't think I want to spend that much, i'll probably just go with the super20G on its own and it'll put me back a couple hundred and put at around 500+HP(super 20g's max) at 12-15 p.s.i., i'll end up running 10p.s.i. at 450+ HP, now tell me that is not good for any motor. Laugh it up and put me down now 4g63 owners, but there is serious hidden power in a 420a, you just have to be willing to put mostly the time into it.
Old 11-25-2004, 08:50 AM
97_3clipse's Avatar
have fun with that wheel hop....
Old 11-25-2004, 10:34 AM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
talonESI where did you get those numbers? have you dynoed your car? those numbers are not anywhere near realistic 700+ at 18 psi LMFAO
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 11-25-2004, 10:42 AM
Lol, TalonEsi, not trying to dog on you but those numbers are nowhere near what you'll actually be putting out. Although the setup is pretty nice, don't expect those kind of numbers, because you will not see them. 300HP naturally aspirated will not happen with that motor, even with those mods. Good luck though, looks like a nice setup.
95 GSX
Old 11-27-2004, 12:21 PM
Zero8985's Avatar
Zero8985 Zero8985 is offline
Send a message via AIM to Zero8985
I feel like i'm in a honda forum right now... this isn't good, guys... j/k
*1997 Mitsubishi Eclipse Spyder GS /// SOLD
*1997 Jeep Grand Cherokee Limited
*2000 Chevrolet Cavalier Z-24 Convertible
My Spyder on Car Domain! Check it out!!!
My Jeep on Car Domain! Check it out!!!
Old 11-27-2004, 08:13 PM
its a side effect of having a NT car.
-1stGenRocks-
