Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 11-20-2004, 12:07 PM
turcy turcy is offline
code P0305
My 98 chevy malibu has a code p0305 which is a cylinder 5 misfire. I've changed the plugs and the coil puts out good spark. The car seems to run fine and i can't I can't feel a misfire when driving. My question is is this code primarily identify ingnition problems or could i have a bad injector.
Old 11-20-2004, 12:22 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: code P0305
This code will set if there is any condition causing a misfire on #5 cylinder...internal engine problem(compression loss) ignition missfire or an injector concern (lean injector)
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 11-20-2004, 01:17 PM
bearcatdon bearcatdon is offline
Re: code P0305
A leaking intake gasket will also trigger a misfire code. Check for coolant leaks.
Old 11-20-2004, 11:26 PM
re
I tried a new spark plug wire today no change. I changed the intake gasket last year so i would hope its not leaking already god help me that its not a compression problem. If i change the injecotor does anyone know if it would be safe to reuse the old upper intake gasket or if it would be smart to just pay the extra couple of bucks for a new set.
Old 11-22-2004, 01:17 PM
bcopeland bcopeland is offline
I had this problem and it was leaking coolant internally. Its not hard to fix - just tedious!
Old 11-22-2004, 07:29 PM
re
I put a new injector in today and the light stayed on until the engine warmed up and then it shut off. does the engine have to be a operating tempature before it will shut the light off.
Old 11-22-2004, 08:33 PM
Re: code P0305
The light came off because the engine started running within its parameters again. Drive it for a few days and see what happens. Unfortunately, I think the problem will come back. Hope I'm wrong.
Old 12-02-2004, 11:51 PM
hoodia hoodia is offline
Injector - A fix?
Did the injector fix the problem? I have a 99 Malibu and tried all the same to fix the P0305. New intake manifold gaskets last year too. Pug, wire, coil, compression, all are fine. Am saving injector till last.
Old 12-03-2004, 12:11 PM
gapboi210 gapboi210 is offline
The other morning I started the car and it was shaking and the Check Engine light was flashing. I turned it off and started the car again and it ran fine. I hooked up a scanner and it said that cyliner number 4 was misfiring at the time. It has been fine ever since. Any ideas? It was raing hard all night. I am thinking that something just got wet.
Old 12-03-2004, 07:00 PM
re
i havent had anymore problems since i changed the injector. It was kinda heartbreaking to pay a hundred bucks for a part the size of my thumb but it fixed the problem.
Old 12-13-2004, 10:17 PM
TheBU TheBU is offline
Re: code P0305
I have a check engine light on.....how do i see what "code" it is???? Do i need a SPecial device or what?
Old 12-14-2004, 05:17 PM
Re: code P0305
Go to Autozone - they read the codes for free,
Old 12-14-2004, 06:55 PM
Re: code P0305
ok....i will go there thxs fo the info
