Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 11-20-2004, 09:57 AM
tommydodge tommydodge is offline
car runs rough (just sometimes)
I have a problem with a 95 t bird, 3.8 liter. Car runs rough sometimes, other times you can't even feel it running. No one i've taken the car to knows what the problem is, I start the car one day and it feels like it's missing like crazy, and runs really rough. then the next time i start it, it runs perfect, no missing or shaking. Someone told me to have the trans fluid changed, so i did and theres no difference, also had a complete tune up. Any suggestions? Thanks
Old 11-20-2004, 04:29 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: car runs rough (just sometimes)
Does it only run rough during certain weather conditions (damp)?
Old 11-21-2004, 06:25 AM
Re: Re: car runs rough (just sometimes)
no, it actually runs better when its raining, could it be a loose ground somewhere?
Old 11-22-2004, 07:56 PM
97Bird's Avatar
Check the computer codes
Old 11-30-2004, 05:40 AM
I have had the computer codes checked and nothing comes up, have had the car to 3 mechanics and no one can figure out what the problem is.
Old 12-03-2004, 05:31 AM
cnote_thunderbird cnote_thunderbird is offline
im having the same problem and took it to the ford dealership and they did a diagnostic check and couldnt figure it out so if some can help that would be greatly apprectiated
Old 12-03-2004, 12:01 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Tonight when it is dark start the engine, pop the hood, and take a squirt bottle of water and squirt down your cap and wires while looking for a pretty blue spark to jump to ground. Next, with the car still running and do this at day or night or whenever, take a can of carb cleaner and spray down your intake where the upper meets the lower and the lower meets the heads. Any change in engine rpm is due to a vacuum leak. Lastly, post on www.tccoa.com and see if the multitude of 3.8 guys there have a clue.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 12-03-2004, 01:06 PM
DanF DanF is offline
Send a message via AIM to DanF Send a message via MSN to DanF
I say plug wires. I know that with changing conditions they can effect the running of you car... though usually it gets worse when raining. I say do the plugs, wires, cap and rotor, that should solve the problem I think, its not very expensive shoudln't cost more than 100 for everything, plus if it doesn't work you won't have to worry about it later... But my vote is going towards your plug wires.
Old 12-05-2004, 05:40 AM
Thanks for all the help, but i,m still having the same problem. I have had the wires, cap,rotor and points replaced, but i still have the same problem. I also have one other problem! When I'm on the highway, the car will just drop out of overdrive, it scuttles back and forth from 4th to 3rd to 4th, it will only stay in third for a second or two, then go right back into overdrive. I've had the car to 2 transmission shops and there are no codes, and no one can figure it out. The car only does these things sometimes, maybe 1 out of 3 times that i take it on the highway.This is driving me nuts because, the car runs perfect other times,and no one can figure out what the problem is. I've had a trans tune up,and complete engine tune up, including changing the wires, cap, rotor,points, and plugs. And cant think of anything else! HELP!!!!
