Old 11-20-2004, 09:31 AM
Sikman Sikman is offline
94 Grand Am key problems
Well, got my 96 Grand am gt fixed, now my 94 Grand am se has key problems. the key will not come out of the key hole...it won't turn back far enough. Also, it shuts off while running because the key thing is messed up. It just turns off if it moves a little.
Anyone? Please?
Old 11-20-2004, 03:48 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: 94 Grand Am key problems
Your problem is a broken ignition switch this is a very common problem on GM vehicles, You can probably find the switch easily on ebay or from a local junkyard and to give you a idea whats involved in changing this here are directions from a Firebird even though its a different vehicle they pretty similiar for your vehicle although I recommend getting a Haynes or Chliton manual for your specific vehicle before you attempt this. Good Luck.
John
http://shbox.com/ignsw/ign_switch_repl.html
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 11-21-2004, 07:22 PM
Forkliftguy's Avatar
Forkliftguy Forkliftguy is offline
Same thing happened on my 1986 Chevy astro van. It really sucked because I was getting gas at the time. I went to start after filling up and the key got jammed just before the start position. I had to push it out of the way so others could use the gas pumps. Good thing was that the switch only cost CDN$23.00 at Canadian Tire.
Old 11-23-2004, 06:35 AM
Ok, I had a mechanic friend look at it and he says I need the whole part where the key goes. It is like $175, but his cost since he works at the dealer is $124. Need new keys and all, not the ignition he says. I really, really wish it had been. Thanks for the replys doods.
Old 09-16-2005, 01:07 PM
kenny1 kenny1 is offline
ok if it is the ignition switch i am pretty sure GM had a recall for that, as i received the letter and took it to get fixed free of charge you should look into it mine is a '97
Old 09-17-2005, 08:14 AM
Thanks, I'll look into that. I've had it fixed since then, but it still acts up.
