Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 11-20-2004, 04:30 AM
Rockgate Rockgate is offline
99 turd?
Well my problem is like I've seen others ask about. Sometimes my truck runs better than others. On occasion after idleing for a bit then tap the gas it sounds like it backfires through the intake. I can drive my sisters 97 runner and it fells like a racecar compared to mine. I even liner them up wioth a friend in mine and me in my sisters 4runner and at a 40 mph puinch hers just walks off and leaves mine. Mine has 102k on it new plugs in the summer, I think pcv valve and any other thing I could replace easily on it. Then check engine light doesn't come on but I know something can't be right. How do you adjust timeing on these things? Thanks
Old 11-20-2004, 09:33 PM
maan maan is offline
try the fuel injecters cleaner it works cool and u will feel the difrnce go to wall mart and buy a pkg of 3 and use one can per fill up try them u will feel it ....go for STP brand
Old 11-25-2004, 09:31 AM
forest_grump forest_grump is offline
Re: 99 turd?
On underside of open hood it should tell you what timing specs are to set at....as far as backfiring...EGR valve been checked???Throttle chamber ever been cleaned(not problem I bet but often neglected and I so often find them in need of cleaning anyways)
Goodluck and happy holidays :o)
Old 12-20-2004, 10:29 PM
MCB777 MCB777 is offline
Re: 99 turd?
I have a 97 and my wife has a 98, 4x4 lim. all the same. I changed the timing belts on both and did a massive tune up on both except I changed her tranny filter. Before, they ran about the same, afterwards hers would smoke mine like a blunt. I therefore changed my tranny filter and they almost run the same. hers has about 45K less than mine. Hers is still a little faster. Try small things like the fuel filter, oil, air ect...
