| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
exhaust rattle.
after driving my car for 10-15 minutes, i can hear my exhaust rattling against either my underbody, spare wheel well, or my rear axle. it gets really annoying on like 45 minute trips when every time i let off the gas you hear this horrible rattling. tomorrow i am going to jack her up and re tighten all the bolts with some loctite. any ideas why this rattling is going on, i could understand all the time, but only after driving for 10 or more minutes.
Like i always say, "I live my life a 1/4 mile at a time, and for those 19 seconds or more, i wish i was boosted..." 2000 Honda Civic EX Just starting... |
Re: exhaust rattle.
you can always go to a muffler shop and have them check it out. I dont think they would charge you much to stop the rattleling. Probably about 30 bucks to weld it better.
-1997 Eclipse Spyder GST |Stock| -1990 Eclipse GSX |ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar| |
Re: exhaust rattle.
check your hangers.
Re: exhaust rattle.
its probably a loose heat sheild. wrap a big hose clamp around it and tighten it up.
-1stGenRocks- 95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's plans: bastard 20g, water/meth injection NO FMIC |
Re: exhaust rattle.
A muffler shop should only charge you like $20 to fix it. Also I would not suggest loctite; just ask any old guy how to break loctite and he'll tell you to just simply "heat it up." Yes, even the high heat stuff.
R.I.P "DIMEBAG" DARRELL ABBOTT "Dime gave it all everyday to each and every one of us and our lives have forever been hollwed without him." - Vinnie Paul p.s. ROT IN HELL NATHAN GALE
This system is all bolt-on so i dont think it is the welding. i am just gonna get under the car and retorque all the bolts. i think it is from the exhaust expanding and contracting so much since i put it on, so the bolts may have become loose.
i'm telling you, it's probably a busted hanger.
exact same thing happened to me about a month ago. one of the hangers busted and the pipe kept hitting and rattling. it didn't rattle the whole time i was driving either. it was one of the muffler hangers, not the piping hangers. check those. |
Re: exhaust rattle.
im beting on the heat shield.
