Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-19-2004, 10:46 PM
JDM00CivicEX JDM00CivicEX is offline
Rod and Main bearings
Will aftermarket rod/main bearings fit on a 97 B20B block or will i have to special order them from honda or hondaautomotiveparts.com due to different crank that came with different B20B blocks? thanx
Old 11-22-2004, 04:20 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Rod and Main bearings
what do you mean aftermarket bearings, whats aftermarket ?
Team Lonely Drivers
Old 11-22-2004, 10:51 PM
Re: Re: Rod and Main bearings
what i mean by that is that the OEM bearings come in different size. The crank has codes stamped on it and so does the block and you have to take the codes up to honda to order different size bearings that will fit on the rods and the crank, but i have found a local autoshop that can get standard size bearings. so i was wondering if those will fit fine, or should i just get oem bearings from honda?
Old 11-22-2004, 11:07 PM
ok if you have the code on the block and on the crank then go get those bearings from honda, or any other place but just make sure you get the right size. use plastigauge to confirm. i dont like using any other bearing other then honda.
im alittle confused on what you mean by standard, do you mean the shop has the bearings that match your block and crank number or does the shop have a standard size that they are gonna give you that might or might not fit.
every bearing has a size and you need to use the correct size
Team Lonely Drivers
Old 11-22-2004, 11:23 PM
Kven's Avatar
Kven Kven is offline
just buy bearings meant for b20b, im sure they have them. ACL brand?
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 11-23-2004, 09:35 PM
so just by standard size bearings ment for b20b block by ACL Brand or do they come different sizes?
Old 11-24-2004, 02:45 AM
Kven's Avatar
they are all the manufactured to spec; OEM sizes. just buy bearings meant for the b20 and you wont have any problems. the b20b crank is actually the same as the LS blocks but i dont know if the bearings are interchangable.
1988 Honda CRX DX
Old 11-24-2004, 03:13 AM
you can buy bearings for the b16, ls, b29 whatevers. the most important thing is the correct size as in thickness of the bearing. std size bearing are good if your block/crank will take the std size.
it looks like none of you have rebuilt an engine before. you cant just buy std bearings if your block takes green bearings, etc because then std wont be the correct size and its either too tight or too loose, either way you will probably end up spinning the bearings and costing you alot more.
you can buy bearings for the b20 but you still need the size, which is thickness of the bearing
Team Lonely Drivers
Old 11-24-2004, 05:51 AM
Kven's Avatar
yup i just did a search on hondaswap and found something; the different colors are the sizes. btw i thought the ACL kits already have the correct sizes? some guy was selling some on honda-tech and he said they were specifically for ls or b20 blocks
Here is a chart of Honda B series bearing thickness by color. To calculate actual bearing clearance, use the following formula:
BC = IDBT - ODC - (2 x BT)
BC = bearing clearance
IDBT = inside diameter of bearing tunnel (housing bore)
ODC = outside diameter of crank journal
BT = bearing thickness
Main Bearing thickness by color
Blue 2.013-2.010 mm 0.0793”- 0.0791”
Black 2.010-2.007 mm 0.0791”- 0.0790”
Brown 2.007-2.004 mm 0.0790”- 0.0789”
Green 2.004-2.001 mm 0.0789”- 0.0788”
Yellow 2.001-1.998 mm 0.0788”- 0.0787”
Pink 1.998-1.995 mm 0.0787”- 0.0785”
Red 1.995-1.992 mm 0.0785”- 0.0783”
Rod bearing thickness by color
Blue 1.510-1.507 mm 0.0594”- 0.0593”
Black 1.507-1.504 mm 0.0593”- 0.0592”
Brown 1.504-1.501 mm 0.0592”- 0.0591”
Green 1.501-1.498 mm 0.0591”- 0.0590”
Yellow 1.498-1.495 mm 0.0590”- 0.0589”
Pink 1.495-1.492 mm 0.0589”- 0.0587”
Red 1.492-1.489 mm 0.0587”- 0.0586”
1988 Honda CRX DX
Old 11-24-2004, 12:45 PM
if memory serves me correctly, acls come in 2 different sizes. usually with a stock block and same stock crank the acls will work but you still need to measure clearance with plasitgauge.
what most people do is they just one 1 set of bearings, somewhere in the middle and just put it on and plastigauge it and see how off it is. so then right there they know how much smaller or bigger they need, and they just do that for ever journal. but you do need a different one of the mains and rods
Team Lonely Drivers
Old 11-26-2004, 02:06 AM
my friends dad whos a master technician helped me with the stamps on the block and the crank, so now i finally know which rod/main bearings to get. thanx for the help all my amigos
