Old 11-19-2004, 08:13 PM
flints flints is offline
2000 Taurus Ax4n Problem
Just Changed My Tranny Filter And Installed New Pan Gasket At 60,000 Miles And When I Was Cleaning Out Pan And Magnet I Found A Large Part Of A Shim Maybe From The Rear Planet Support Assembly,etc. Stuck To The Magnet.it Is 3 1\4 Inches In Width And A Little Over Half Complete.i Did Read That Ford Was Adding A Shim\spacer Due To Wear Prolems.the Tranny Seems To Work And Shift Fine But I Am A Little Concerned About The Above.can This Piece Be Replaced Without Taking The Tranny Out Of The Car?any Help Or Info On Above Would Be Appreciated. Thanks
Old 11-22-2004, 08:13 AM
mwt mwt is offline
I wish I could help you out but I don't know about the shim.
Where did you read about it?
I would like to read up on that
Thanks
Mike
Old 11-23-2004, 08:06 PM
Re: 2000 Taurus Ax4n Problem
Thanks
Mike
HI MIKE,YOU CAN GET THIS INFO AT SONNAX.COM,I THINK THE SELL TRANSMISSION PARTS THAT ARE UPGRADED.IT IS A SHIM PLACED BETWEEN THE REAR PLANETARY SUPPORT ASSEMBLY AND THE CASE .FORD PART NUMBER F6D2-7C144-AA.YOU WILL NEED A NEW REAR PLANT SUPPORT ASSEMBLY TO GO WITH SHIM PART NUMBER F6D7-7A130-CA.I WENT TO FORD GARADGE TODAY AND THEY THINK MY PROBLEM COULD BE THE SHIM OR SPACER.WILL LET YOU KNOW HOW I MAKE OUT IN A FEW WEEKS . FLINTS
