| Off-Topic Talk about anything other than cars. |
Vacuum Hoses
I am in the process tonite, of replacing 2 v. hoses. They both were cut, or melted, and the base of were they plug into, so i have no idea what order to put the new lines back on. I have a 91 non-turbo. I have the ends that connect to the throttle body all perfect, just the other end. I replaced both of the green dashed lines, the one that goes in the middle slot on top, and the one that goes way in the back below the ISC. I have the little plug to put them in, but i just don't know what hose goes where, there are 2 hoses, and 2 slots, and i'm afraid if i pic the wrong one, something bad might happen, since i need the car in the morning(my only car). Also, if somebody has a spare plug, i would love to buy it, since mine isn't in good shape, but will need to be used for the time being. Thanks for any info.
Re: Vacuum Hoses
look at the emmisions/vac line routing diagram on the underside of your hood
-1stGenRocks- 95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's plans: bastard 20g, water/meth injection NO FMIC |
Re: Vacuum Hoses
The haynes/chilton manuals at autoparts stores have decent vac line diagrams too, but to read them you need to know what the components are and where to find them.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
Yea, i have a haynes manual, but that didn't help too much. I found the diagram on the hood, and now i feel stupid. I got my vav. lines done, but i still have bad idle surge, and when i adjust the BISS(without doing any of the grounding stuff), it does absolutly nothing to affect it. I don't know now.
Re: Vacuum Hoses
is the oring on the biss good? even without doing the grounding stuff the biss should raise and lower the idle it just wont be permanant
i don't know, i still do have the cap over the top and everything, if the O-ring were to be bad, could i feel a vac. leak, or should i just take the screw out, and change it, with the car off of course.
Re: Vacuum Hoses
i would just change it. get a new biss and o ring from mitsu for 5 bucks total.
The only problem is the closest mistu dealer, is 400 miles away, would a crysler dealer work?
