Old 11-19-2004, 07:11 PM
juki_gt juki_gt is offline
Question what is ETS system ?
Hi everyone i have a question .What is ETS system and how does it work ?Should i drive with ETS always on or should i turn it off?Thanks in advance
juki_gt
Old 11-19-2004, 09:54 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: what is ETS system ?
ETS ( Electronic Traction System ) is suppose to give your car better traction in rain and snow. When it feels your car's tires spinning, it cuts back on the throttle until they grab. It's really mainly just bells and whistles - I only use mine when it's rainy or snowy outside. It robs horsepower and makes it a lot harder to burn out. Deffinately turn it off if you're racing. The last thing your computer needs to be worrying about is tire slippage when it should be worrying about fuel delivery. My overall advice: (ETS - OFF except in snow / rain )
Old 11-20-2004, 12:06 PM
grfnkl's Avatar
grfnkl grfnkl is offline
Send a message via AIM to grfnkl
I wouldn't rely on the ETS at all. It's a nice touch on the car, I agree it robs power. It only works OK at times... but it can be quite dangerous when it kicks in OR DOESN'T kick in. I definetly would never trust it in SNOW, you are better off turning it off. For whatever reason mine never works properly in the snow and has caused me to get into an accident with a telephone pole.
Old 12-01-2004, 12:18 PM
The Right Formula's Avatar
The Right Formula The Right Formula is offline
Send a message via AIM to The Right Formula
ETS on a GA does nothing at all. It's there for peace of mind so when moms are driving their kids around in rain or snow, they are lulled into a false sense of security. SAme thing with jeeps, 4wd SUVs, etc. People have them and think they are impervious.
I've chirped with ETS on and with ETS off. I've spun with ETS on and with ETS off. Personally, I always have mine off. I find it easier to control the car by ~my~ will (other than what computer thinks is best for the 'then and there').
2002 Light Pewter Metallic Formula A4:
Cold Air Intake with sealed MTI Airlid, ported and polished TB, smooth bellows
Old 12-20-2004, 11:05 PM
geldartb geldartb is offline
how do i turn the traction control off i have a 99 ga and i know where the button is . how long do i hold it to shut the trac off
Old 12-21-2004, 12:02 PM
Ridenour's Avatar
GranddAmnit
You should just be able to push it firmly once, and then release it. you shouldn't have to hold it down
Old 12-23-2004, 11:28 AM
orangemonsterkid orangemonsterkid is offline
Send a message via AIM to orangemonsterkid Send a message via Yahoo to orangemonsterkid
I went to San Diego a few weeks ago when it was DOWNPOURING. My ETS kicked in, alright...alright for a useless battery draining lightbulb. There was an immense amount of water on the road and The only thing that happened when my tires spun was a light came on that said "LOW TRACTION". I ended up manually relaxing the throttle in order to get ground. I had no idea about it draining power from the engine...does anyone know if it drains power from the battery as well?
Old 12-23-2004, 03:44 PM
grfnkl's Avatar
It only takes power from your engine and shouldn't effect the battery, if you ever have problems like that with it constantly kicking in, just turn it off it'll making driving that much easier.
Old 12-26-2004, 06:33 PM
autozonesucks2000 autozonesucks2000 is offline
all it does is keep your wheel from spinning so badly that it may explode from centrif force It is BS if you canot tell you are losing traction get out from behind the wheel please.
