Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 11-19-2004, 06:29 PM
caddy57 caddy57 is offline
wheel interchange
I would like to get rid of the donut spare on my 96 Trans Sport, and would like to know what, if any other GM wheels would fit. Mine are standard 15 inch steel w/ wheelcovers.
Thanks in advance
Steve
Old 11-20-2004, 09:35 AM
ciras3's Avatar
ciras3 ciras3 is offline
Re: wheel interchange
You're not going to be able to get a standard 15" wheel to mount up under the back of your van and fit into the space for the spare tire.
"Just because the cat has her kittens in the oven doesn't make them biscuits."
Old 11-20-2004, 12:37 PM
Well on returning to FL. This fall , I had a blowout and had to use the spare for 350 miles.I carried the front tire under the back without any problems whatsoever, and even the manual suggests putting the regular tire on the hanger for safekeeping
Old 11-20-2004, 12:50 PM
LMP's Avatar
LMP LMP is offline
Indeed from almost day 1, I have always carried a full size spare there under, cause I have 4 snow tires on separate wheels. SO in summer, my spare is a snow tire, and the opposite in winter.
ANd I do not think it is hard to find exact matching wheel from wrecked transports, and I think 15 in wheels from full size buicks and olds of those years are also perfect matches.
Old 11-20-2004, 03:14 PM
ciras3's Avatar
Originally Posted by caddy57
:.I carried the front tire under the back without any problems whatsoever, and even the manual suggests putting the regular tire on the hanger for safekeeping
You're right... I looked in my manual and it does tell you to do that. I would never thought that my full size aluminum wheel would have tucked under there.
Old 11-21-2004, 07:26 AM
Re: Re: wheel interchange
Thanks so much for your reply. I am replacing all 4 tides and will use the buick for a spare
steve
Old 01-08-2005, 04:42 PM
timguyli timguyli is offline
Does anyone know what other GM cars use rims that will fit a 95 trans sport? thanks
Old 01-09-2005, 09:09 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
I would check a Hollander manual which a lot of salvage yards use. It has a section that lists parts for vehicles and what other vehicles it can also be used on. I checked tirerack.com and they have plain steel wheels for a '95 for $68 each. I got my wheels for my '97 at tirerack and they were only $37 ea, cheaper than the local salvage yards, and the yard's wheels were used . I'm not sure if the next generation Transport and other van rims would work, but would think the Lumina, and Silhouette should work from '96 and earlier.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
