Old 11-19-2004, 05:03 PM
Captain Mark's Avatar
Captain Mark Captain Mark is offline
Question Removing tape residue
Howdy folks,
So I've pulled all the masking tape (Tamiya brand) from my NSX, and have found that there's some marking where the tape was. I don't believe the paint has lifted, but rather some of the sticky 'stuff' from the tape has remained on the paint and is just visible with the right light reflection on it.
I've tried cutting compound, then kerosene to get it off, but no luck yet. And I'm reluctant to try sanding as I've spent sooooo long on this paintwork I don't want to sand through to the undercoat and have to start over.
So, does anyone have any tips for getting rid of this masking tape residue? Any help greatly appreciated!
Cheers,
Mark
Old 11-19-2004, 05:06 PM
Ran's Avatar
Ran Ran is offline
Re: Removing tape residue
I have no experience with paint, but if it wont take off the paint, maybe put a bit water on the spot and rub it gently off?
Please don't do this without thinking a few times, I don't want to be the cause to the wreckage of your model.
Ran
Please read the AF guidelines
if you haven't read them before.
Old 11-19-2004, 05:10 PM
Hi Ran, that's the quickest response I've ever seen! Don't worry, I'm thinking long and hard about how to fix this problem.
The kero didn't affect the paint, so I would assume water would be fine too. However I'll be testing everything on a spare or inconspicuous part first. I'll post here if the water works.
Thanks.
Old 11-19-2004, 05:28 PM
ImolaEK's Avatar
ImolaEK ImolaEK is offline
Re: Re: Removing tape residue
Thanks.
That has happend to me plenty of times. Just wetsand it with 2000 grit and then use compound. Be careful to run through the paint. It might be wise of you to shoot a light coat of clear over those areas that the tape has lifted.
-Joeham-
無限 MUGEN POWER
Email:
[email protected]
MYSPACE
www.myspace.com/joeham
Old 11-19-2004, 06:19 PM
primera man's Avatar
"P-Man"
I've never known the tamiya tape to do this. Are you sure its stuff left from the tape?
You may have taped to soon after painting and left marks in the paint due to it being not dry enough.
View All My Models Here.
Old 11-19-2004, 09:45 PM
freakray freakray is offline
AF Modelrater
Sounds like what P-Man is talking about, how long did you wait after painting before masking?
AF User Guidelines
Old 11-19-2004, 09:56 PM
About 3 weeks between a clear coat and masking (for black trim).
Problem is now fixed!
I used 4000 grit sandpaper to get the bulk of it off, and then cleaned up the area with Tamiya cutting Compound. Good as new!
Although, I've handled this kit so darn much that it seems there's the odd blemish coming up in the bodywork. Ah well, too late, now... and that's another story.
Cheers folks.
Old 11-20-2004, 07:56 AM
Ran's Avatar
Ran Ran is offline
Thanks.
You're welcome, glad to help
Ran
Old 11-22-2004, 04:37 AM
hueb_s's Avatar
hueb_s hueb_s is offline
I had the same probs with my ESCI M1, the paint was not really dried... I usually use alcohol-based Tamiya acrylic paint (from the little bottles) and this stuff needs WEEEEEKS to dry completely. It also dries from the outside to the inside, meaning when the surface is dry, it doesn't mean the whole paint job has thoroughly dried...
I just waited, wet sanded with #6000 and sprayed over with a bit clear, wet sanded again before decaling and final clear cote...
Best Regards,
Steffen
