Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-19-2004, 04:06 PM
SSZero's Avatar
SSZero SSZero is offline
Is there any way to make it so you can safely shift in an automatic without...
Hey guys. I just wanted to know if there's any way you can shift in an automatic (without having to change it to a manual) without beating up the transmission... Any suggestions for what I should do to the car?
'96 Green Eclipse GS-T
Stock for now...
Old 11-19-2004, 04:54 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: Is there any way to make it so you can safely shift in an automatic without...
my mom has autostick in her car....its a manual without the clutch..
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 11-19-2004, 05:21 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
where did you get that picture of my girlfriend?
DSM geek
Old 11-19-2004, 10:31 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
an autostick (except Ferrari/Maserati and SMG) is NOT a manual without a clutch, its a plain old automatic with an electronic override.
Leaving your automatic in drive is faster than trying to shift it yourself.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 11-20-2004, 01:01 AM
george536's Avatar
george536 george536 is offline
The best thing is just to make your foot heavier for the gas pedal. lol just drive is enough. L 2 3 that dont matter cuz your auto shift rite before it hits redline.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 11-21-2004, 07:32 PM
SSZero's Avatar
Re: Re: Is there any way to make it so you can safely shift in an automatic without..
I don't know about that... I heard you get better times when you actually shift the auto...
Stock for now...
Old 11-22-2004, 09:14 AM
kjewer1 kjewer1 is offline
AF - Advisor
Depends on the car. In a grocery getter it will be "tuned" to shift at relatively low rpm. On sports cars they are typically programed to shift at the optimum rpm for accelerating. Someone I know ran a 3g eclipse and shifting manually it was never faster than letting it do it on its own, no matter what he tried. But as variable change so will optimum shift points. The tranny is programmed for a stock motor with stock HP curve. A modified motor may need to shift at higher rpm, etc. Only way to find out is to do both and see what works. We can all discuss this on the internet all day, but in the end the timeslips will be more accurate
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-25-2004, 11:40 PM
SSZero's Avatar
Yeah, that's true. But hey, if all else fails, shiftronic will save me...
Stock for now...
