Old 11-19-2004, 03:06 PM
Kaz2003 Kaz2003 is offline
removing the alternator on a crx si
It took me a long damn time to get the alternator out of the engine compartment. Its easy to get it off its mounts but if the lower mount bolts are stuck on the frame then the best thing to do is get a cheater bar or breaker bar with enough leverage you can knock the bolt loose.
Take the splash guard off near the driver side wheel and the alternator will come out that way so much easier. I was just so damn frustrated while trying to get my alternator out that I had to tell people how to get it out of the car so no one else will be as frustrated as I was. If you got any other questions about the alternator or battery or voltage regulator just PM me laterz.
Old 11-19-2004, 03:08 PM
!M!}['s Avatar
!M!}[ !M!}[ is offline
Re: removing the alternator on a crx si
u can take the alt. out the top of the engine bay just slide it across the back of the motor and bring it up where the intake pipes goes done it may times befor
Old 11-19-2004, 03:27 PM
1990civicdxhb's Avatar
1990civicdxhb 1990civicdxhb is offline
Re: Re: removing the alternator on a crx si
my aslernator just went out yesterday,
I'm buying one today,
so I hope I have good luck,
I think im going with the slide around the back of the motor,
take out from the intake area!
thx
In the process of B00stin my D
