Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-19-2004, 12:57 PM
riff22 riff22 is offline
what size fuel pump?
i have a 95 talon tsi im asking for 550cc injectors, and a walbro fuel pump for christmas. i plan on putting a 14b on the car and later on down the road a 16g. my question is should i get the walbro 190lph or the 255lph? wasnt sure if the 255 was to much to run with the 14b or not
p.s. if this means anything i might be getting a safc2.
thanks
tyler
Old 11-19-2004, 01:13 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: what size fuel pump?
you'll need the safc2 in not a diffrent fuel computer to compensate for the added fuel. if your not going to be going largere then a 16g. i'd stay with the 190. the 255 upgrade does not required to get an ajustable fuel pressure regulator, but it is highly recomended. ether way, rewire your fuel pump when you do it.
flow charts
http://www.roadraceengineering.com/f...pflowrates.htm
good thread that explains a bit about flow.
http://www.automotiveforums.com/vbul...&highlight=255
DSM geek
Old 11-19-2004, 01:30 PM
so if a get the 190 it requires an ajustable fuel pressure regulator, and the 255 doesnt? and will it hurt to have the 255 if i have the safc2. i just dont want to end up going bigger later on and having to buy another on cuz i didnt get the 255
Old 11-19-2004, 03:00 PM
you "wont" need a afpr for the 190. you "might" need one for the 255. but you "will" need a way to controle the extra fuel the larger injectors will put into your combustion chamber. if your planing on going larger then a 16g, buy the 255hp, afpr (one that allows you to decrease fuel pressure), fuel pressure gauge, safc2 & pocket logger or dsmlink.
www.dsmlink.com
www.pocketlogger.com
DSM geek
Old 11-19-2004, 09:00 PM
kjewer1 kjewer1 is offline
AF - Advisor
I feel that a 255 should definitely get an AFPR. Its not worth having jacked up fuel trims and other odd behaviors, spend the 2-300 bucks.
Doing some quick figuring, it seems that at a target AFR of 11:1 and pump gas (Specific Gravity of .76 assumed) and 22 psi boost, the 190 matches the 550s at 100% IDC almost perfectly. About 130 LPH and 40 lbs/min supported airflow. An EVO 16g has the potential to go over 40 lbs, but anything smaller should do fine with this setup.
BUT, if you think there is any chance you might go bigger someday, go big on fuel now. Get the 255 HP and the regulator and be done with it. It will cover 950s at low boost (25 psi) and 850s to 35 psi. And yes, if you change injectors to anything nonstock, you need an AFR type device to compensate, no way around that (exept injector compensated chip, etc.).
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
