Old 11-19-2004, 11:55 AM
Bob Phillips Bob Phillips is offline
How do I remove door panel on '97 Silverado
Need to know how to remove door panel w/o damaging panel
Old 11-19-2004, 12:29 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
Re: How do I remove door panel on '97 Silverado
It should be the same as the panel on the 96 i used to own, it should be just a matter if removing any screws in the door panel then just getting ahold of the panel on the edge towards the bottom of the door and work your fingers in behind it (or get the proper tool) and pull straight out, to this alonf the bottom and up both side being careful once getting towards the top. Once this is done lift up on the door panel to remove the top edge that is hooked in the top of the door itself and unplug the wires for the light/locks/power mirrors ect. That should be all , then just reverse the procedure to reinstall it.
Old 11-19-2004, 01:24 PM
Smile
Thanks Kenny, I appreciate your help!
