Go Back   Automotive Forums Car Chat > Ford > Probe
Old 11-19-2004, 08:51 AM
blindfoldedhope blindfoldedhope is offline
Send a message via AIM to blindfoldedhope
Question Probe Problems
First i need to know how to take out the dash board and does the gauge cluster come out at the same time... Im gutting another probe for parts to paint...
Second My car smokes badly on cold starts after sitting for like 7 hours its probally rings////seals but does anyone know anything i can do to cut it down and keep from the embarassment every day after school lol.
also where is the best place to run wires through the fire wall
Old 12-06-2004, 04:24 PM
quicksilverz017 quicksilverz017 is offline
Send a message via ICQ to quicksilverz017 Send a message via AIM to quicksilverz017
Re: Probe Problems
i dont know
Old 12-06-2004, 05:36 PM
Re: Probe Problems
to run wires through the ire wall you have to drill but if its power wires for the amp of somthing fin them through the crack of the door form the hood thats perfect cant even see them. the gauges you dont have to take out the front part of the dash. for your car smoke problem you need rings becouse the iol is sinking through the rings and uirning like gas that world make it smoke and not start good and if its white smoke you need headgaskets or heades or u can go to autozone and get smoke begone thats works to. but if u wanted to run wires throught the fire wall srill to the left or the clutch or break bedle in the top that works great to but its freaken hard to do that
Old 12-08-2004, 11:49 AM
avfan avfan is offline
Re: Probe Problems
my probe smokes like that after sitting also the easiest way to hide it is go out at lunch and start it ,also any no-smoke oil additive will help some, but you are looking at some head work in the near future
Old 12-08-2004, 12:26 PM
96probegt's Avatar
96probegt 96probegt is offline
Re: Probe Problems
if your car only smokes on start up or after sitting for a while chances are you need a valve job or valve guides if it where rings it would smoke all the time
Old 12-08-2004, 05:39 PM
Re: Probe Problems
right,i would put my money on valve guides since it apparently stops after running awhile-guides get warm and start sealing better. as far as the dash,i have an 89 probe lx with a digital dash and half of my bulbs went out. i got a haynes manual and it was fairly thourough on how to pull the thing out
Old 12-08-2004, 05:44 PM
girlie_GTS girlie_GTS is offline
Send a message via AIM to girlie_GTS Send a message via MSN to girlie_GTS Send a message via Yahoo to girlie_GTS
Re: Probe Problems
Does anyone online own a GTS probe?
Old 12-09-2004, 01:36 PM
96probegt's Avatar
Re: Probe Problems
i own a 96 gt the only differince between the gt and the gts is the rear bumper
Old 04-21-2005, 11:51 PM
probeIDAHO probeIDAHO is offline
Re: Probe Problems
Where ran my gauge wire, was through a rubber gromet located about a foot above the brake pedal and a few inches to the left. it should already have wires running through it (dont know what to) but there is enough room to make a insision for the gauge wire. Look hard it hidden. when found it a piece of cake. I frowned upon the idea of drilling a hole in my firewall.
