Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-19-2004, 09:43 AM
mekwilliams mekwilliams is offline
Send a message via AIM to mekwilliams
1992 Rodeo NO FUEL *Confused*
We just got a 1992 Isuzu Rodeo 6cyl, 3.1...we knew it was not running when we agreed to get it, but thought we would work on it. The previous owners had the timing chain replaced, drove it home where it sat for a while, then would not start again. Timing was checked...appears to be in time. Checked the fuel pump...was not kicking on...so we though hey, there is our problem. We got access to the fuel pump, getting ready to order one to replace it, hot wired it directly to battery, and it worked...pumped fuel straight up to the throttle body and out return line. We tried starting it...would not start...dumped a little fuel into throttle body...tried real hard to start but still wouldn't.
Checked the injectors, there is no fuel coming from the injectors.
Seems to us that it is something electrical...stoping the fuel pump and injectors.
Read something about a PROM in the 3.1's only in the computer. Don't know if this has anything to do with it...or if it is the whole computer...
PLEASE HELP IF YOU CAN!!!
UP TO ANY SUGGESTIONS
THANKS!!!
Old 11-22-2004, 04:06 PM
For anyone looking for an answer to my question...WE DID IT!!!! Found a large blue wire under steering column...power supply for fuel pump...this wire had been cut...put back together and HAD POWER!!! Then injectors were not firing....replaced w/ some from junk yard...still not firing...replaced computer w/ one from junk yard...still nothing! Found group of wires on ds of engine bay...ground wires for injectors, were not connected...NOW TRUCK RUNS!!!! Just wanted to let you all know incase anyone was having any similar trouble...may be bad ground for you too....
