Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 11-19-2004, 08:28 AM
Blackthunder92 Blackthunder92 is offline
Unhappy Oil in the air filter
Hey guys...I have a 1992 Jeep Wrangler 2.5L 4 cyl. I just got the head machined and am in the process of putting my engine back together after a bad overheating incident. Before it overheated, I was getting some oil in both the oil filter and intake manifold. I already checked to see if the vaccum fitting on the valve cover was clogged. It was not. Has anyone come across this problem or have any suggestions? Thanks.
Old 11-24-2004, 08:29 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Oil in the air filter
You may have been getting some blowback with the head problem. I'd clean everything out well, then check periodically to see if the problem is still there.
Old 11-24-2004, 10:23 PM
Dale Aeppli Dale Aeppli is offline
HI, FOLLOW THE HOSE FROM THE PVC VALVE BACK TO WHERE IT GOES INTO BOTTOM OF THROTTLEBODY ITS A SMALL LINE IT PLUGS UP WHERE IT GOES INTO MANIFOLD, CLEAN LINE OUT COMPLETELY. DALE [email protected]
Old 11-25-2004, 09:34 PM
Thanks, I'll try to clean the hoses out. There is no PCV Valve though. But that sounds like it could work.
