Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-19-2004, 07:09 AM
YellowITR479 YellowITR479 is offline
Car goin crazy...Scan says misfire in cylinder 1 & 3...help
I was flying around as usual yesterday when all the sudden it felt like my car just lost all fuel or ignition. Wouldnt really go anywhere and was definately not road worthy. I pulled the plug wires off the coil while it was running to see if i was getting spark and i was and i ran an OBD-2 scan and it said i was having a mis-fire in cylinders 1 and 3 and a high MAF voltage. What the hell is going on here, i thought i might of had a ground problem but it looks intact....anybody ever had this happen to them?
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights,
2000 Integra Type R: Totaled
Old 11-22-2004, 04:18 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
check your timing, check timing belt tdc, then check dist timing.
Team Lonely Drivers
