Go Back   Automotive Forums Car Chat > Racing > Drag Racing
Old 11-19-2004, 05:30 AM
7T4MULA's Avatar
7T4MULA 7T4MULA is offline
Send a message via AIM to 7T4MULA
What should I run in the quarter????
I need some help.
My best ET prior the the mods I am going to list was 13.5, on street tires, all I did was carb swap, exhaust, and 3.55 gearing.
Mods...
Ram Air III heads, Ported and polished, custom bowl work and vlaves
Ram Air III intake manifold, ported and matched to cylinder heads
Holley 760cfm 4bbl double pumper carburater
Richmond 3.90 gearing in 12 bolt positraction ass
Edelbrock IAS Shocks
Edelbrock IAS Springs
Stock (trans Am) front and rear sway bars
Lakewood traction bars
BFG Radial TA tires, P245 60 R14's
Power Master Alternator
Power Master High torque starter
MSD ignition system
3 Tube Ceramic Coated Doug Headers (big ass tubes)
3 inch dual exhaust half way back dumped before axle
Flowmaster 3 chambered Super Series 40 Mufflers
Comp. Full hydraulic roller camshaft and lifter kit
Comp. Springs and push rods, etc.
JE (unknown size) Pistons and rings
Unknown manufactor connecting Rods
Holley Fuel Pump
3,000 RPM stall Converter
B&M Street / strip shift kit for TH-400
What should I be trapping with street tires? and what do you expect I will run if I ever get the balls to add slicks? or at least DOT street tires?
-1970 Pontiac Firebird Formula 400 Ram Air III
Old 11-19-2004, 06:39 PM
RedLightning's Avatar
RedLightning RedLightning is offline
Re: What should I run in the quarter????
umm, I have no idea, but wanted to say sweet car. My mom used to have a 70 or 71 bird. Unfortunatley she cant remeber what model it was.
1993 F-150 Lightning
Mods-March UD pullies, Ltngdrvr CAI, Flowmasters, E-fans, and Eibach / Bell-Tech Drop Kit in the garage.
http://www.cardomain.com/ride/2149061/1
Originally Posted by KustmAce
Real emo kids kill themselves.
Old 11-20-2004, 07:12 PM
90redgt 90redgt is offline
what size motor? 350? i'd say you'll be close to 12's if not running 12's on a regular basis. Ehh, but unless you had a real shitty carb before and crappy exhaust before also, then i doubt it'll really take off .5 seconds. If your shootin' for 12's slap on some slicks.
1990 Mustang GT.
Old 11-21-2004, 10:40 PM
7T4MULA's Avatar
350 lol no its a 400 CI
Old 11-24-2004, 02:22 PM
SLAYTANIC_1134's Avatar
SLAYTANIC_1134 SLAYTANIC_1134 is offline
I would expect you to be well into the 12's with those mods. I love the early 2nd gen firebirds. DOT slicks should also take off another .2 - .3 sec. That car looks like a blast; good luck and as long as you beat turbo imports, that's all that matters.
R.I.P
"DIMEBAG" DARRELL ABBOTT
"Dime gave it all everyday to each and every one of us and our lives have forever been hollwed without him."
- Vinnie Paul
p.s. ROT IN HELL NATHAN GALE
Old 11-24-2004, 02:57 PM
JekylandHyde's Avatar
JekylandHyde JekylandHyde is offline
AF - Advisor
Re: Re: What should I run in the quarter????
7T4MULA, sweet ride. I have no experience to base a judgement on your ET/MPH improvements, but generally speaking Drag Radials will give you .2 to .3 and slicks will give you .3 to .5 from what I have seen.
Originally Posted by SLAYTANIC_1134
... as long as you beat turbo imports, that's all that matters.
Yeah, that is the only thing matters.
Is it easier to close a mind when it's small?
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
Old 11-24-2004, 07:04 PM
Zgringo Zgringo is offline
Sounds like you've had a problem with turbo'd imports. Have you talked to a shrink about this?
What about supercharged imports, same issue?
7T4MULA, cool ride. Keep us posted with times. Should be faster just with gear changing, but with the engine mods, you might be showing your donkey to alot of cars.
