Old 02-25-2002, 06:58 PM
engsr's Avatar
engsr engsr is offline
CAI - lower revs?
i installed an AEM CAI w/bypass valve about a month ago. now, i've noticed that my car at lower speeds revs a bit higher than with my stock intake system (about 400 rpm difference). the rev difference isn't there at highway speeds, or while idling, just in slower city driving. i did reset the ECU and even hooked up the stock oxygen sensor. so, did i install the CAI wrong, or is this a common occurence? thanks for any help.
Bryan.
Pure Honda member since August 2001
AF Nordic Crew #002
Old 02-26-2002, 05:55 AM
VTECseoul VTECseoul is offline
Send a message via AIM to VTECseoul
R U sure UR not driving faster? at startup when engine is cold i noticed it idles higher, but after warming it settles down to normal.
2000 Honda Accord LX Satin Silver Sedan
AEM ColdAirIntake
Neuspeed Sport Springs
Nitto 450 225/50
Prime Racing M8 17x7
S15 vs AE86 - 2006 HotWheels Touge
Old 02-26-2002, 10:17 AM
b16a3sol b16a3sol is offline
the question is what kind of tranny do you have? no matter what you do to the motor, if you leave the tranny the same nothing will change with the speed to rev ratio, as long as you have a manual. with a stick, the tranny is attached to the engine directly meaning that the speed is directly related to the gear ratios and the revs of the engine. if the gear ratios and the tranny are untouched, the spped will always be the same for every point in revs. if it is an auto, it is close to the same, but no always, especially at lower speeds.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 02-26-2002, 10:34 AM
Rice-Rocketeer Rice-Rocketeer is offline
In continuation to this, if you somehow mess up or don't reconnect the AIT sensor, the engine will stay at warm up rpms (higher rpms) until the intake manifold itself warms up which could take 15 - 20 minutes of driving. You might also get rpm spiking where it goes up and down continously at idle until it warms up.
Lookin at my gucci, it's about that time...
Old 02-27-2002, 12:09 AM
engsr's Avatar
put it this way:
stock intake: 5th gear, 70km/h = 2000 rpm
AEM CAI: 5th gear, 70km/h = 2400 rpm
after the engine warms up, the idle settles at 800 rpm, like it always did. no spiking either. any speed higher than 100km/h there is no difference in rpm.
Bryan.
AF Nordic Crew #002
Old 02-27-2002, 11:16 AM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
Since you've got a 5th gear, I assume you've got a 5-spd manual transmission.
This means that one of the following is most likely the problem:
1) your tach has never given consistent readings
2) you've accidentally messed up the wiring for the tach, resulting in an error
3) your speedometer doesn't give consistent readings
2) you moved your seat, and the apparent position of the tach has changed
3) you changed to smaller tires and thus changed the overall drive ratio (and didn't tell us about it)
As was previously mentioned, in a manual transmission there is a fixed ratio between tire speed and engine speed for each gear. There's no way to change this ratio without changing internal transmission/differential components (unless you count slipping the clutch). If your tires are turning at the same speed (same size, same vehicle speed), and you read a different value from the tach than you used to, either you or the tach has made a mistake. Since you're using the speedometer to judge vehicle speed, you can add another possible source for your measurement error.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 02-27-2002, 12:00 PM
Spunkymonkey's Avatar
Spunkymonkey Spunkymonkey is offline
I agree.
I haven't had any problems with my CAI.
There's a chick driving that thing
www.performanceforums.com
Old 02-27-2002, 12:02 PM
Thats normal dude.
Old 02-27-2002, 08:31 PM
fritz_269's Avatar
fritz_269 fritz_269 is offline
I agree with Ivy Mike entirely. With a manual tranny, the engine RPM to the MPH is a fixed ratio, no engine part can possibly change it.
Old 02-28-2002, 10:05 AM
engsr's Avatar
hey guys, thanks for the help, much appreciated. i guess i must be going crazy
Bryan.
AF Nordic Crew #002
Lowered BMW problems... :-( Ashleyyy 3 Series 0 04-18-2010 12:30 AM
Lower radiator hose cool/Water pump squeal ktl4974 Problem Diagnosis 7 05-04-2009 08:44 PM
AEM CAI Rev limit hunterhk2k Prelude 3 04-24-2005 01:38 PM
Cheap Civic CAI & Lowering Springs ivymike1031 Cars/Parts for Sale/Exchange 2 08-27-2003 11:01 AM
shifting at higher revs, better than at lower revs ?? 96LSIntegraRocket Engineering/ Technical 9 05-03-2002 12:53 PM
