Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-19-2004, 01:04 AM
big_sam_2004 big_sam_2004 is offline
Simple Question... I think....
I know the 93-97 camaro's had the LT1, as the 94 - 96 b-body's did, but I heard they were slightly different, I just need to know will the SLP Loudmouth exhaust system hook up the same way it would to a camaro? (with the LT1 installation kit)
Here's The link
http://www.lmperformance.com/711/2.html
The Installaton kit is at the bottom, also, which one works with it, if any?
Old 11-19-2004, 04:35 PM
TommySS TommySS is offline
Re: Simple Question... I think....
Just because the engine is the same doesn't mean you have the same exhaust plumbing.
From the down-pipe to tail pipe, F and B Bods are totally different.
Old 11-22-2004, 12:27 PM
Hooptie's Avatar
Hooptie Hooptie is offline
Tommy is correct. Everything is different. Your better off with a B-body specific cat-back. I would say they probably flow better than the F-body set up anyway. The difference everyone usually refers to in the two engines is that the F-bodies have alluminium heads and the B-bodies have Iron
Old 11-22-2004, 02:27 PM
thanks for clearing that up for me, i thought the f and b body LT1's had iron heads and the LS1 had aluminum heads....... but i could be wrong
Old 11-23-2004, 01:53 AM
Hooptie's Avatar
B-body had Iron heads. F-Body LT-1 had Alluminium heads and the LS-1 is completely Alluminium, even the block
Old 11-24-2004, 04:33 PM
All the plumbing is different between the cars even if you have identical heads
