Old 02-25-2002, 06:43 PM
darrenj's Avatar
darrenj darrenj is offline
Question Clear coating on clear plastic
quick question from the newbie
I gave my 93 Subaru impreza a clear coat and then attached the clear plastic windows after. I feel I need to put on another coat of clear.. can one clear coat over clear plastic??
Does Tamiya sell clear coat in ready to use spray can?
I find mixing clear coat and thinner and using the airbrush is a hit and miss process I am getting fustrated with!!!!!!:flash:
check out my first modelling project ....Brabham diorama
http://www.angelfire.com/de2/darren/brab.html
Old 02-25-2002, 06:51 PM
daggerlee's Avatar
Yes, I believe it's TS-13. Be careful if you're using with Tamiya spray paints though!! Regular tamiya spraypaints and TS-13 have different curing rates. The Tamiya clear cures and hardens much faster than regular Tamiya spray paints. As a result, escaping gas from the underlying color coat will cause your clear coat to crack!!
Also, if you're using an airbrush, go to the local supermarket (food market), go to the Cleaning supplies section, and pick yourself up a bottle of Future Floor Finish! This stuff is great! It's thin enough to airbrush straight from the bottle, self-levels, and dries in one day! You also get 27 oz's of the stuff for 6 bucks
Hrm, actually on second thought, you live in Sweden so you won't find it under the "Future" brand name. I believe it's called either SC Johnson & Johnson Floor Finish, or Klear or something like that.
In fact, here's an excerpt from an online guide:
In the end I carefully dip the whole part in Future Floor Wax (or Johnsons Floor Wax for plastic floors, as it is called here in Sweden) and let it dry overnight. The result is short of a miracle: the canopy usually ends up so shiny and transparent that it's hard to believe that it is the same part! I recommend you to try it one day!
Hope this helps!
Old 02-26-2002, 02:47 AM
darrenj's Avatar
Lightbulb
originally from daggerlee
Amazing will check this out ASAP...
as the swedes would say..."Tack så mycket"- thankyou very much
(pronounced- tak so mucket)
:flash:
Decals - Clear coat & Sanding grit Zman007 Auto Collision Network 1 12-24-2010 07:52 AM
Clear coat clear parts? cyberkid Car Modeling 13 07-08-2006 02:56 AM
clear coat on black plastic.... dmbrisket 51 S-10 9 04-24-2005 09:15 PM
Quik query : Clear coat on clear plastic Sticky Fingers Car Modeling 6 02-01-2005 12:23 AM
clear coating clear view? UKSupraboy Car Modeling 3 07-04-2004 09:11 AM
