Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 11-18-2004, 10:18 PM
GBJ GBJ is offline
89 Crown Vic idle surge
I have a regular, pulsating engine speed surge at idle. It occurs only when the engine is at operating temperature. The idle air control valve has been replaced. The engine is a 5.0 liter and is a California gasohol experimental vehicle according to the emmissions label. Any suggestions on a cure?
Old 12-06-2004, 01:02 PM
landyacht's Avatar
landyacht landyacht is offline
If it's a special vehicle, i'd see if you can't trace down the folks that made it a special vehicle and ask them what they would suggest. If it's a regular 5.0L i'd have the idle checked, it may be a little high.
If it's a carburated motor (but i think they had done away with carbs by then?) then i'd say ur butterfly valve on the carb is sticking.
Hope that helps somewhat...
Mine's an '82 Pontiac Parisienne 4-door sedan!!
- 305 cu inch (5.0L) small block V8 w/ 3spd auto
- 4 barrel carb w/ single exhaust
- No catalytic converter, no posi-trac
NEVER LOSE FAITH IN THE BOAT!!
Old 12-07-2004, 03:48 PM
radioman2002 radioman2002 is offline
I have had a problem with the MAP sensor which is located on the passenger firewall. You should check that the vacume line is not leaking. A quick fix a mechanic friend told me about was take the handle of a screwdriver and give the map sensor a rap. If the MAP is the problem it should stop surging. if not make sure the IAC wires are plugged in, I have had a car where the plug was bad causing all kinds of problems. As far as a special vehicle, and that it was a test car for gasahol I doubt thats the problem, most gas has up to 10% alcohol in it. I did buy 2 Methanol fuel cars from the state, and there was no difference, I even used the computer from those cars on others.
