Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 11-18-2004, 09:14 PM
b18ls's Avatar
b18ls b18ls is offline
Banned
rear lower control arms
Who makes a good rear lower control arm for a 2000 integra LS?
Old 11-19-2004, 12:54 PM
b18ls's Avatar
Banned
Re: rear lower control arms
Bump... also, what are the benefets of upgrading if your keeping stock wheels.
Old 11-20-2004, 09:25 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
SRR makes some, as well as Megan Racing I believe.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 11-21-2004, 02:16 AM
BullShifter's Avatar
Re: Re: rear lower control arms
less weight, less unsprung weight, & stronger. while many do it just for looks. if that's all your concerned with just paint your stock LCA's & put that $$$ towards something else.
Old 11-21-2004, 02:35 PM
Cali Guy
Re: Re: Re: rear lower control arms
Couldn't say it any better myself!
hessemer69 on AIM
Old 11-22-2004, 01:50 PM
b18ls's Avatar
Banned
I've been big into Honda B-series engines for about a year now and realized I didn't know anything about the suspension past coilovers and strut bars. Thanks. What else should I be looking at? It's for a 2000 Integra with hopes of around 200 HP.
Also, for a full coilover set, which would be better Tein or Cusco (if price were the same)
fISH...
Old 11-22-2004, 02:14 PM
TIRES! are the biggest factor when it comes to handeling. acceleration, & braking. Without tires none of those would be possible.
Cusco & Tein both make good products. Just make sure you get a coilover setup with adjustable dampening. That allows the user to adjust the ride feel for the conditions, soft for the street, hard for racing.
Comparing the six bars you can install a rear sway bar will have the biggest effect on handeling. Next would be a rear lower tie to help prevent the frame from twisting. After that upper strut bars(front / rear) and finally lower front tie.
Those cheap upper strut bar & lower tie bars sold on ebay are for looks not function. you want the ends to be solid not on a hinged point. If a "brace" can move what's the point?
To get the full benefit of adjustable coilovers all four camber kits are needed and the car should be corner weighted. Like I always say every time the ride height is changed alignment & corner weight should be done. Coilovers can be a pain if just on the street. Most people just eye ball the ride height and go with not knowing what the hell coilovers are even for.
http://www.ybapublications.co.uk/sho...stribution.htm
When it comes to suspension do not be cheap, price does reflect quality.
Polyurethane bushings are also something to look into but a warning about them - in cold climates they turn cement hard causing a very harsh ride, unlike rubber bushing poly can be very noisy if not lubed correctly or often. Mugen makes a nice rubber kit.
