Old 11-18-2004, 08:17 PM
305sr 305sr is offline
problem with my amp
i have a 2 channel 1600w boss amp and its been working fine for like 2 weeks then it just completely turns off like no power is running to the amp. it not hot or the red light turns on. its just completely dead. can any of u guys help me with this?
Old 11-18-2004, 08:22 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: problem with my amp
check the fuse in the power wire
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 11-18-2004, 08:32 PM
the thing is that when it turns off the next i turn it on then it goes off again could it still be the fuse??
Old 11-18-2004, 08:49 PM
sr20de4evr's Avatar
how long is it on before it turns back off?
'01 Black Sentra SE
'05 Silver WRX STi
Old 11-18-2004, 08:52 PM
maybe for like 30 mins.
Old 11-19-2004, 02:27 AM
2centproduction 2centproduction is offline
Your amp is not of high quality. The heatsink on it probably sux. The amp turns off as a mechanism designed to save it from overheating or blowing. Once so much power is put out the amp is told to shut off. This is my guess. I've had amps do the same thing, mainly Bazooka. Once it shuts off you have to turn the deck off and then back on, then the amp will turn back on again when it gets the signal. If this is the problem it will only get worse as the amp gets older.
