Old 11-18-2004, 06:52 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
350 mods
guys does this sound good. im using the center bolt heads off of my 305
on my 350, also i will use a LT4 hotcam. the engine before already had 307 hp when built by my friend for his z28, will putting my heads on it and throwing in that cam up the hp any higher, or will it complicate things.
Old 11-18-2004, 07:26 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: 350 mods
only complication i can think of, is depending on the parts used to build the engine before, you might have sky high compression with the swap to 305 heads, and not be able to run pump gas, or any gas for that matter lol.
also the hot cam might have too much lift for those heads to handle without mods, and the flow of the heads might not support the high lift of the cam, and they will not see the added benifit. but im not sure. these are just possiblities.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 11-18-2004, 07:47 PM
Re: 350 mods
i may just keep the engine the way it is and drop it in. its a healthy 4,500 mile engine. i may just do headers and a hi flo cat.
Old 11-18-2004, 08:00 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
you can get away with just under .500 lift with flat top pistons and the stock valve springs on your 305 heads. should be able to use pump gas too
Old 11-19-2004, 01:22 AM
89IROC&RS's Avatar
Re: 350 mods
a 350 with 305 heads, flat top pistons, and thick head gaskets will be running around 10.5:1 compression. if you build it right, you can run premium pump gas. but i wouldnt do it.
Old 11-19-2004, 03:07 PM
4onFloor's Avatar
i've done it before and it works fine. it even works with 89 octane.
Old 11-19-2004, 03:14 PM
im just going to leave it the way it the way it is, it will be faster to do it that way for me. i have painted it and the 6 speed gloss black. and im going to drop the rear end and put in a 373 posi.
