Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 11-18-2004, 06:09 PM
craig87crx craig87crx is offline
CRX injectors...
Besides the stock injectors, are there any other injectors that will thread into the stock manifold that would better performance? I'm replacing the injectors and I'm wondering if I should do an upgrade now. Thanks.
Old 11-18-2004, 07:17 PM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
Re: CRX injectors...
I wouldn't swap the injectors without also swapping on a bigger throttle body. The reason for this is because if you only swap in bigger injectors your car will just run rich. But if you balance out more fuel with more air, then you will see some power increase. You can use the injectors and TB from an '86-'89 Integra D16A1, though you will have to construct an adapter plate in order to bolt on the throttle body. There are no adapters available anymore and there are no TB's that will simply bolt on. If you go to all this trouble of swapping parts, you should also consider swapping in a bigger cam in order to take advantage of the other swapped parts. If you need injectors now, you'd be better off with stock replacements. Later, after you have the throttle body and camshaft, you can install an adjustable fuel pressure regulator and increase the pressure for more fuel which will give you the same effect as bigger injectors.
Old 11-21-2004, 07:07 AM
revhalzoo revhalzoo is offline
dont run bigger injectors even with a bigger TB, the map sensor will just pick up an incrase in manifold vaccume and adjust the fuel injectors to dump more fuel. if you want bigger injectors you will need to be able to program them.
Old 11-21-2004, 11:16 AM
Will the cam from the D16A1 bolt into my D15A3? Will this offer any improvement if I also use the TB?
Old 11-22-2004, 12:56 AM
Figori's Avatar
Figori Figori is offline
Send a message via Yahoo to Figori
Not at all. The heads are no where near the same.
"Short, sweet, and to the point"
1987 CRX Si - Project Si 'RexSi'
1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL.
2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ?
