Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 11-18-2004, 05:12 PM
72 rs's Avatar
72 rs 72 rs is offline
help with drive axle
im having problems pulling my passenger side axle out on my 97 mitsu gallant. it just wont move...i know its just suposed to pop out with a lil pressure, but its not.
ive tried a pry bar, a really big pry bar, a slide hammer( after i ripped the axle apart and did some custom work on a few tools). any help would be awsome.
Old 01-20-2005, 08:43 PM
steve9899 steve9899 is offline
Re: help with drive axle
I'm having this same problem with my 99 Diamante, passenger side axle.
Shop manual says to hammer on the support bracket, then to pry at the transaxle.
It moved out maybe 1/8" at most when I hammered on it, and it hardly budges at all when I pry on it.
Does it usually take a tremendous amount of force to remove these?
What kind of pry bar do people use for this? I'm trying a couple different sizes of demolition bar. Small one doesn't give enough leverage and large one doesn't get in the tiny gap very well.
Would it be OK to use a chisel to wedge it out instead of prying? I'm afraid of damaging the oil seal if I do that.
Old 01-29-2005, 09:41 PM
Str8in Str8in is offline
Banned
Send a message via AIM to Str8in
I found a good way to pop the axles out is to get a fairly sized chizel. Put it where the axle meets the tranny and hit it with a hammer it should pop right out
Old 01-30-2005, 04:10 AM
Re: Re: help with drive axle
For the next person who searches...
The passenger side axle does not have to be pried at all!
The support bracket where the inner and outer axles meet was hanging up on the block. Once I jacked the car up farther I realized this and was able to move it around, then the axle pulled right out.
