Old 11-18-2004, 04:30 PM
LilMack1957 LilMack1957 is offline
Battery Light on
Just a very quick question. Suddenly the battery light on the dash is on but the gague says 12 volts steady. Can the alternator be gone and still have a 12 volt reading?
New to dealing with car repair so please help
Thanks
Old 11-18-2004, 05:59 PM
mrfirebird mrfirebird is offline
it's probably your battery going,not taking a charge. stop by advance auto and they will check it for free. should be around 14+ volts when motor is running.
Old 11-18-2004, 07:38 PM
Fireplug Fireplug is offline
Re: Battery Light on
Wow m8
A 12 volt reading IS BATTERY voltage only . With the truck running you should have 13.8 min to almost 16 volts depends on different systems.
So if you have a 12 volt reading you are on battery power only and that will not last long. Have the alternator checked and I bet it needs replaced.
Old 11-18-2004, 09:58 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
This is an pure alternator problem.
Replace it immediately or you will be stranded very soon.
When the alternator gives out, it will rely on the battery to power the truck when running which will last for a short time and then become dead as a doornail.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-19-2004, 09:55 AM
ad6kb ad6kb is offline
I concur, had the same thing happen a few weeks ago. Needed new alternator
