Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-18-2004, 02:14 PM
zman2800 zman2800 is offline
Question 96 Eclipse ECU Question/Swap
Someone plz help!! Just got a 96 2.0 Eclipse A/T Non Turbo and I have come to find out I need a ECU. Does anyone know if I have to get a 96 non turbo a/t ecu or can I cross years and type of eclipses? the dealer wants $700 and the pick-u pull wants $36 but they do not have a 96.
Thanks.
Old 11-18-2004, 04:24 PM
real_madridcf's Avatar
real_madridcf real_madridcf is offline
Send a message via AIM to real_madridcf Send a message via MSN to real_madridcf Send a message via Yahoo to real_madridcf
Be sure to check the FAQ sticky at the top of the forum, it is really helpfull plus you dont have to wait for a reply. As for your question i found this at the 1000AAQ site. Be sure to check it out.
Site for ECU Compatibility
1000 AAQ (This is originally where i found the other site from)
Good Luck!
95 Eclipse GS: OBX Full Exhaust System, OBX Headers, OBX Short shifter, OBX Spark Plugs & Wires, 17' MSR Rims w/ Wanli tires
96 Eclipse GS-T : K&N Filter w/ Hardpipe, UICP & LICP, Greddy Type S bov, Greddy Boost Gauge
Hala Madrid!
Old 11-18-2004, 04:57 PM
Re: 96 Eclipse ECU Question/Swap
Good Luck!
COOL! thanks for the help. Let me throw this one out since I can not find a answer to this one. Maybe I am searching with the wrong words.
One problem with the car is that when I first start it from sitting all night the cooling fans kick off right away before it even heats up, I am getting a big draw on the alternator. At first I thought it was the fans but I pulled connecters and still get the draw. For the first few seconds of startup it shows 14.7 on a meter then drops down to 13.2 and the battery light then comes on. Then you can here the engine load down from the load on the alternator. I have unplugged and tested with the cooling fans, starter, ac, and then I have pulled every fuse from under the dash and under the hood. Still shows 13.2 on the volt meter. (this is a test meter not the one in the car) I got a new battery and new alternator. Also there is no aftermarket radio or amp in the car. Cigarette lighter has been unplugged to. Anyone this could also be the ECU. I am replacing the ecu due to stalling issues. ( and the tps and iac have been replaced for that problem). I would like to really enjoy the car.
Old 11-18-2004, 07:04 PM
hellah fresh's Avatar
hellah fresh hellah fresh is offline
hey let me know if yur new computer works. I also need some advice my car wont start after i replaced everything. I swapped my motor... so do i need the ECu from the same year too?
1996 Mitsubishi Eclipse RS -Red ****UPDATE**** My car is no more! R.I.P. 12/12/05
Mods: 420a DOHC equipped with: bored 54mm throttle, 2.5" cold air intake, 2.5 chrome headers, 2.5 Down Pipe, 2.5 resinator, 5" 2.5 flared muffler, 2.5 custom piping, Megan front & rear strut, Megan rear lower tie rod, Monroe Shocks, Aerospeed coilovers
Rollers: 18" TSW Throphy / Pirelli P7000 225/40/18
