Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 11-18-2004, 01:58 PM
Shiftee97EX's Avatar
Shiftee97EX Shiftee97EX is offline
Send a message via Yahoo to Shiftee97EX
Instument Panel
Okay, so I had to take my civic to the smog referee to bypass the stupid readiness test and he wouldn't test it because my SRS light did not come on. Is this as simple as something like a blown out light or a fuse? I need to get this done to get my tags and I don't want to take it to a tech if it is something that I can do. Let me know if anyone has had experience with this before. I did a search and could not come across this issue. Your help is greatly appreciated.
Thanks.
Old 11-18-2004, 02:27 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: Instument Panel
Thanks.
eek, I hope for your sake it's just a light bulb.. If a fuse was blown, non of the instrument lights would work, so that's not it. If you want to check the bulb, take out the two phillips screws up top, holding on the plastic thing around the cluster. After you gently pop that off, you'll see four screws holding the cluster onto the car. Undo those, then pull out four wireband clips off the back. Pull out the SRS bulb off the circuit board stuff on the back to see if it's busted. If it is or you can't really tell, try swapping it with a non vital bulb that fits it just for testing, like a turn signal bulb or something (your signals will still work).
After swapping those, put the cluster back in your car and start her up. The SRS light should come on for like 5 seconds then go out.. If it doesn't, you're screwed! I honestly don't know what that thing is..
Old 11-18-2004, 10:10 PM
97CivicX's Avatar
97CivicX 97CivicX is offline
Send a message via AIM to 97CivicX
Re: Instument Panel
i thought srs and cel were on a separate fuse. the haynes manual isnt telling me much, maybe someone knows?
D16Y7/D16Y8 mini-me swap
turbo coming this summer
Old 11-19-2004, 02:35 PM
Re: Instument Panel
I'm going to take a look at it tomorrow while changing my sis-in-law's fuel pump. I haven't checked the Hayne's yet either. It would be great if it is as simple as the fuse. Thanks for the input. If worse comes to worse I will take the panel off and test the lights like Ricochet mentioned.
I'll let you all know what develops...
Old 12-01-2004, 06:23 PM
Re: Instument Panel
Do you know where the SRS module is located?
I think this may have something to do with it.
Old 12-02-2004, 02:45 PM
Re: Instument Panel
Nevermind I found it.
Checked my Haynes when I got home...
