Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-18-2004, 12:57 PM
BamaRodeo BamaRodeo is offline
Cool Timing Belt replacement interval
I've read here numerous times that the T-belt and tensioner should be replaced between 30k-60k due to the fact that it tends to break or come off during that time. In saying all that my question is: If I had the T-belt and tensioner replaced due to a recall at 24k, when should it be replaced again? Better yet, if you replaced the T-belt and tensioner at 24K at what interval should the next replacement be???? (ex. 24k - 48k - etc???)
Thanks!
'99 2.2L Rodeo
'06 Mini Cooper
w/ guitar in back
Old 11-18-2004, 01:18 PM
ibew595's Avatar
ibew595 ibew595 is offline
Send a message via AIM to ibew595
Re: Timing Belt replacement interval
84k max. unless you feel real lucky.
email"A.F."in subject line only
Mt. Hamilton 9/03
Kevin Goto
2000 740 i
Impala Brown
Annalisa
Old 11-18-2004, 01:48 PM
SOLSTER SOLSTER is offline
Does the same interval hold true for the +98 3.2L (I noticed this thread was started by a 2.2L owner)? Could someone here offer some advice on maintaning the timing belt.
Also, you may look into replacing the water pump while you're in there, that's the word I've been seening in this fourm, but again, I believe this is on the +98 3.2L, not sure on other models.
Good Question, and I'm currently at 60K, so I'll be interested in following this thread.
1999 Isuzu Rodeo S 3.2L, 4x4, Auto, Great Truck!
2007 Pontiac Solstice GXP, Aggressive Red
Old 11-18-2004, 11:45 PM
mrprogrock mrprogrock is offline
Send a message via AIM to mrprogrock Send a message via Yahoo to mrprogrock
The water pump on pretty much any vehicle that has it mounted on the engine block and driven by the timing belt should be replaced when the timing belt is replaced. The new belt will be tighter and the old water pump will fail before the next time you have to replace your timing belt. That means you'll pretty much have to do the same job twice and you risk overheating your engine....and if you have the 3.2L with the aluminum engine, it CANNOT take overheating and consequently the head gaskets tend to blow easily. Its better to just spend a little extra cash, kill two birds with one stone, and be safe rather than sorry. Hope that helps.
