Old 11-18-2004, 11:36 AM
Pimpdady753 Pimpdady753 is offline
Question Super Charger Help
Hello, i know this is not the place to put this, but i could not find a spot to put it so please help me. I was woundering if you could point me in the right direction, i want to know the difference between a turbo charger and a super charger like how they work. If you could give me some web sites that tell me. also of some web sites were i can get some good ones for my ford mustang. THANK YOU. please help me.
Old 11-18-2004, 11:59 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Super Charger Help
supercharger:
connected through a belt to the engine, the belt turns the compressor which compresses the air, which is then forced into the engine. The extra air combines with extra fuel, and more air + more fuel = more power.
turbocharger:
the exhaust gases leaving the engine expand through a turbine, which is connected by a shaft to the compressor. The incoming air is compressed, sent to the engine, yadda yadda yadda.
The end result is that both make power in the same fashion, but a supercharger is a parasitic power adder, meaning it requires power from the engine in order to compress the air and make more power. As a result, with everything else being equal between a SC and a TC, a SC will make about 40-100hp less than a TC (depending on how big of a gain we're talking here).
But on the other hand, since turbos run off the exhaust gas, at low rpm or low throttle there isn't enough exhaust to turn the turbine, and therefore you don't get much, if any boost. As the rpm increases, eventually you hit a spot where the turbo starts spinning and making boost, that extra boost runs through the engine and makes even more exhaust, which turns the turbo faster, etc, and basically you get a huge surge of power. The time it takes before you hit this point is called turbo lag, if you've ever ridden in a high hp turbo car I'm sure you've felt it. This doesn't exist with a supercharger since it's always cranking out boost, regardless of rpm or throttle position (to a point).
Turbos also tend to be easier on the engine because they don't make so much power at very low rpm, which can be detrimetal to your rods and crank, depending on the car and how overbuilt the engine is.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 11-18-2004, 02:44 PM
ok now can you give me some web sites were i can get a turbo at. for a ford mustang thanks.
Old 11-18-2004, 04:10 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
www.inductionconcepts.com
