Old 11-18-2004, 11:28 AM
packertundra packertundra is offline
2001 Windstar - intermittent no start
I have a 2001 Windstar LX. 2 times I have driven it recently and I'll turn it off to go into a store and when I come back to try and start it it turns over and tries to start but quits. Its seems like it is either not getting fuel or getting too much fuel and it quits.
The first time we had to have it towed and then the next day it started right up for the mechanic and he said he couldn't do anything without being able to reproduce the problem. It happened again and I took it in to a different mechanic yesterday. He suggested that it might be that the fuel pump was going out on it but he too didn't really feel like he could troubleshoot it without it happening.
Does the fuel pump sound like the culprit or could it be something else? Is there any way I can figure this out without having to be stranded again?
Paul
Old 11-18-2004, 12:01 PM
12Ounce 12Ounce is offline
Re: 2001 Windstar - intermittent no start
The fuel pump may well be the culprit, but try the $10 fuel pump relay first.
My '99 is still on its original fuel pump @ 150k mi, but I'm probably on the 12th relay.
Consult your glove box manual for location.
Old 11-18-2004, 02:24 PM
The section in the manual that I'm looking and find reference to the fuel pump relay is in the fuses section. Does that sound right?
Old 11-18-2004, 02:31 PM
It does for the '99. The relay was one of about 1/2 dozen in the fuse-box next to the battery.
Old 11-19-2004, 02:48 PM
Any idea how to get the Power Distribution Box cover off?
Old 11-19-2004, 04:37 PM
DRW1000 DRW1000 is offline
Yeah that is a tough one. on my 99 there are tabs on the sides that need to be released. Sorry that it is not much of a description but at least you now know what to look for. It always seems to take me about 1/2 hour to remove the cover.
Old 11-20-2004, 02:56 PM
The "hinges" are on the front, the clip-latches on the rear. I find it helpful to press down on the center of the lid, while also lifting upwards on the rear latch.
Old 01-20-2005, 09:31 AM
rhe rhe is offline
Lightbulb Re: 2001 Windstar - intermittent no start
My 2000 3.8L had this symptom. The engine would actually start when the key was at the start (cranking) position, but shut off immediately when the key was relaesed to the run position. My ford mechanic called the factory; they advised replacement of the idle air selenoid. Intermittent connections had been common, and caused this symptom. The car never failed to start since (5 months). Lucky I was still under extended warranty (no charge).
Old 06-26-2005, 03:55 AM
SamGitlin SamGitlin is offline
Re: Re: 2001 Windstar - intermittent no start
On the 2002 there is a hinge on the back, impossible to release. Managed to get this off once, would really like to find a better way, been suggested I use a bent wire hanger.
Any other thoughts here from the 2002 Windstar owners would be appreciated.
Thanks!
Old 06-26-2005, 06:21 AM
Wink
Bent wire hanger works, easy on and off now! PS Best of luck with your current situation!
