Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 11-18-2004, 10:30 AM
henrymv henrymv is offline
98 monte and a mass airflow sensor code
My monte is getting a code for the mass airflow sensor. the repair shop took it out and cleaned and the cleared the code, drove it awhile and it looked like the problem was solved. After about 25 mins. of in town driving the check engine light came on again and the engine died. I was able to get it started and drove it back to teh dealer. Has anyone else experienced a similar problem. The mechanic does not think it is the sensor. I am wondering then if there could be a bare wire sending a bad signal. Any help and input would be helpful. Thanks
Old 03-31-2006, 10:39 AM
ulies8 ulies8 is offline
Re: 98 monte and a mass airflow sensor code
check the lower intake gasket and the upper plenum intake gasket also the air flow valve
Old 03-31-2006, 02:48 PM
maxwedge maxwedge is offline
A990 racer
What engine?? Any intake work done recently?
Old 03-31-2006, 03:52 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
did you check the new code that tripped the light? If you have a re-usable K&N type air filter installed, the oil from that style filter wreaks havoc on MAF sensor elements.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
