Old 11-18-2004, 09:00 AM
calebmilla's Avatar
calebmilla calebmilla is offline
Eclipse GS-T w/freshly built motor for sale
1995 Mitsubishi Eclipse GS-T 5-speed, Texas car! NO RUST! The engine and transmission have been rebuilt less than 5,000 miles ago! Like new! The transmission was sent away to B&M for rebuilding (w/LSD) and engine was rebuild using JE .020 forged pistons, the block was bored out. Also used were Crower pistons rods, a nitrated crank shaft, and ARP Bolts. While the engine was being rebuilt a 1st gen head, intake manifold, and throttle body were used to replace the 2 gen equipment. Some of the other goodies added to the mix were Prothane motor mounts, a new water and oil pump, a WALBRO 255 Fuel Pump, 680cc Injectors, a big 16G and 35mm Wastegate Flapper, a Greddy Type-S BOV, and an E-Prom Chip. Just recently (less than 500 miles ago) a Toda timing belt was installed by Pure Tuning in Toledo. While they were at it they installed a new harmonic balancer, accessory belts, a new half shaft, and a new o2 sensor.
For anything else I might have missed here's some more.
-APEXi SAFC-ll
-Halman Manual Boost Controller
-APEXi Turbo Timer
-APEXi GT Downpipe
-APEXi N1 Cat back
-2100 ACT Clutch
-New slave cylinder and master cylinder
-New Shifter Cables
For the Suspension:
-Tokico Shocks
-RSR Springs
-Ingalls camber kit
-Front and rear strut tower bars
-New steering connecting rods
-New front upper control arms
-97-99 Bumper conversion (the bumper was damaged down by the lower lip but doesn't effect performance.
-Projector headlights
-97 GSX Wheels, powder coated gunmetal
-225/50r16 Kumho Esta Supra 712 - 2 brand new and 2 are about half tread.
-Drilled and slotted rotors in the back
-New brake pads all around
-New windshield
-Optima red top battery
-Tripple A pillar pods - air/fuel, volts, boost
The car is a Texas Car up until 2004 and has a clean Car Fax report. The body is good but has normal wear. The body has about 130k miles. There's no rust and it's very clean underneath since it is a southern car. It has never seen snow! As you can see I've taken care of everything that it might need. The only thing it needs now, before it can make massive horsepower, is a front mount intercooler.
Will consider trade for a GSX or 8,500 firm.
Old 11-18-2004, 10:30 AM
real_madridcf's Avatar
real_madridcf real_madridcf is offline
Send a message via AIM to real_madridcf Send a message via MSN to real_madridcf Send a message via Yahoo to real_madridcf
pics??
95 Eclipse GS: OBX Full Exhaust System, OBX Headers, OBX Short shifter, OBX Spark Plugs & Wires, 17' MSR Rims w/ Wanli tires
96 Eclipse GS-T : K&N Filter w/ Hardpipe, UICP & LICP, Greddy Type S bov, Greddy Boost Gauge
Hala Madrid!
Old 11-18-2004, 11:32 AM
calebmilla's Avatar
Here's a link to a pic.
http://gt.streetracing.org
