Old 11-18-2004, 01:13 AM
spunger spunger is offline
OBS Parking Brake adjustments???
I have a 91 K1500 pickup with some sad parking brakes. The brakes are new, less than 3,000 miles on them. When I press me E-brake it goes to the floor and feels like it's not grabbing anything. When I let off to let it reverse it feels like my pads are gone but I have new hardware, drums, shoes, and what not. I dunno exactly how to adjust the E-Brake cable but I can learn
Any tips or ideas/how-to's would be greatly appricated!
Thanks,
Chris
Old 11-18-2004, 08:48 AM
joe92k1500's Avatar
joe92k1500 joe92k1500 is offline
Under the driverside CAb of the truck, there is a point where the Emergency brake has an adjuster. Basically three cables comming to one point with a metal cage. In the cage you should see a threaded rod on one cable with a nut on it. This is the adjustment. tighten it up. My Haynes manual says three clicks of the parking brake pedal is the point where the brakes should start to catch. This is assuming the rear brakes were done correctly. Make sure they are adjusted correctly and the Ebrake cables are attatched, and not broken! if one cable is broken you will not be able to adjust the cable at all. Hope that helps.
