Old 11-18-2004, 01:01 AM
yjjgqfd yjjgqfd is offline
2001 service engine soon light
I've got a 2001 s-10, 4wd, ext. cab, 4.3, 5speed with about 79000 miles on it. About 9000 miles ago the service engine soon light came on and has stayed on.
I took it to autozone and they said they couldn't read that specific code. I then got a our mechanic at work to test the thing and it came secondary air intake system (code was 0400 or 0410??). He didn't really have a clue where to start, said it could be anything.
You guys have any ideas before I take it to a dealer. Thanks,
Casey
Old 11-18-2004, 11:24 AM
busa_4 busa_4 is offline
Re: 2001 service engine soon light
get a repair manual to see how the secondary air injection system works. if you dont know how it works it is hard to repair. chiltons or haynes manuals have diagnostic steps you can follow to repair the problem. i would have to say there is a faulty vacuum valve. check the valve and make sure it holds vacuum. if its a solenoid, check the solenoid and make sure it clicks. also, there are times when carbon buildup cloggs the valve and related parts . remove the carboned up parts and clean them.
Old 11-18-2004, 10:16 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Air injection system has condensation in it.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-02-2004, 07:27 AM
sweetcoupe sweetcoupe is offline
had that problem.....if i unplugg the ground on the battery for like 15 mins....light goes away
Old 12-03-2004, 10:10 AM
Mikado14 Mikado14 is offline
This appears to be a common problem due to the location of the pump. If it comes back on, you may want to remove the pump and dry it out. Also, there is a 30 AMP (I think) fuse located in the engine compartment for this.
