Old 11-18-2004, 01:58 AM
lobo789 lobo789 is offline
Angry 91 cavalier engine stalls or stops
My car is 91 chevy cavalier 3.1 v6. it has the engine stalling or stop problem. this problem always comes with 15~20 mins driving. engine stalls or stops when apply the break or slow down to traffic light. I got check engine light, check gasge light, and battery light on. sometimes I can restart it up right away, but sometimes I must wait about 2~3 mins to restart it up. I took it to two different repair shops and GMC dealer to inspect this problem but they had no any solution. i always add fuel injection cleaner but it won't help.
TPS has been replaced
IAC has been replaced
TCC has been replaced
all the hoses are connecting properly
Any suggestion, please help me .................is Crankshaft position sensor failure
Old 12-24-2004, 07:51 PM
sweets87 sweets87 is offline
Re: 91 cavalier engine stalls or stops
i have the exact same problem with my 91 z24
it might be the crankshaft position sensor but i just had mine replaced and it did nothing. actually its been stalling more since that. i have done everything that has been suggested on any and every forum about 91 z24 stalling and have yet to find the answer
good luck, let me know if u get it figured out
Old 12-24-2004, 10:17 PM
godenm's Avatar
godenm godenm is offline
i know this sounds stupid and like a small thing to do,but did you try changing the fuel filter?
Old 12-26-2004, 01:52 AM
everything to do with fuel injection etc has been looked at, tested and some replaced
Old 01-15-2005, 12:12 AM
89cavalier 89cavalier is offline
I have an '89 Cavalier that did the same thing to me once. There is a good chance it could be your torque converter solenoid (small part - I think its actually part of the transmission and relatively cheap).
Old 01-15-2005, 12:32 AM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
You can unplug the TCC an you will find out - most people that have the problem which is common with the TCC unplug it rather than replacing it - its safe doesnt damage anything an will most likely solve your problem - if u unplug it an u still have problems then its not your TC
93' Stealth R/T Twin Turbo Intercooled - 24v DOHC 3.0 v6 engine - AWD AWS - 320 hp 317 lb ft. torque when I bought her unmolested hoping to be in the 600-700 hp when finished with ...
~FASTER THAN A SPEEDING TICKET~
Old 01-15-2005, 12:34 AM
my dads 89 Z-24 2.8 cowl induction had the problem with it stalling an what not an then when it gets hot enough the tc would lock up -(rev high when stopped like it was in high gear) so we unplugged it an it works like a champ runs strong as hell an no problems since
Old 01-31-2005, 10:32 PM
Robbobby Robbobby is offline
Send a message via MSN to Robbobby
where exactly is the tcc plug cause i am getting stalling issues as well like my 92 2.2l chugs then when i press the gas its like it has lost its power if i take it from park to drive it stalls then it will start up again but i have to manually idle it so it doesnt stall for 10 min till it finally idles on its own. any suggestions or can you tell me where to unplug the tcc?
Old 02-01-2005, 12:34 AM
noshun's Avatar
noshun noshun is offline
I'd go with this too. Get underneath and look at the tranny. There is a plug (electrical) on it. That's it!
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
Old 02-01-2005, 10:17 AM
kamakasi kamakasi is offline
Send a message via AIM to kamakasi
here ya go on front of tranny there is the torque conrverter plug (blue) unplug it ur good to go mechanic told me
Old 02-01-2005, 06:18 PM
atlanticl atlanticl is offline
Send a message via MSN to atlanticl
what about head gaskets? maybe there's a hole(s) or a leak in the gaskets area.
Try putting in rubber pellets to fix the leak. You get them from auto stores.
Old 02-01-2005, 06:28 PM
It could be the crank shaft failure, but I doubt it. I could also be your alternator, since the battery light is coming on while you're driving. Or it could be both, but hardly.
The crankshaft sensor only dictates the central computer which plug to spark. As you're saying, you get this problem while driving, so your spark timing is ok. The only time a battery light would appear is when your alternator is not feeding the electricity to the battery while the car is running.
Old 02-01-2005, 08:43 PM
noshun's Avatar
The lights are coming on because the engine has stalled, as simple as that. If the igniton is switched on and the engine stops all of these lights WILL light up!
Old 02-01-2005, 10:30 PM
dido ^^^
Old 02-02-2005, 12:04 AM
Re: Re: 91 cavalier engine stalls or stops
oops! sorry 'bout that. Yea you're right about that. then in that case, I would narrow it down to the crankshaft sensor and the head gasket.
