Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 02-25-2002, 02:32 PM
miker miker is offline
Lightbulb '02 Remote Keyless Entry
Check it out... new car problems (no sympathy needed):
I can lock / unlock doors, pop the trunk and lower the windows. But I can't close the sunroof or roll up the windows. My wife says it's a safety feature, but who cares, I want it to lock down like Fort Knox at the push of a button.
Any ideas? Can this feature be added?
Yes... I have nothing better to do or more important things to worry about...
1967 Mustang GTA Fastback
2002 Maxima SE w. six speed trans.
Old 03-30-2002, 05:51 AM
boogieman boogieman is offline
Good news and bad news...
Good news -- it's possible.
Bad news -- if you are not familiar with taking the car apart and doing some wiring, then it's not possible.
You can simply purchase some window roll-up modules. Many manufactures make them, DEI, Clifford, etc. The module is connected to constant power, windows or sunroof, and the "armed" signal wire. Once armed, or locked, the module will roll your windows up and close your sunroof. It's not too hard. However, if you are not comfortable about doing that, I am sure any alarm installation place can do it for you. These modules usually run under $50 each for 2 windows.
Hope this helps...
Boogie On!!!
Old 11-21-2002, 08:53 PM
squam1 squam1 is offline
not sure about the sunroof, but you can close the windows by inserting the key into the door lock and turning the key to the lock position. Hold the key in the "lock" positing for several seconds and the windows will close - you have to hold the key until the windows are completely closed - it is not an auto up close - that's why you have to hold it...
-chris
Old 11-21-2002, 11:19 PM
un4gvnbb's Avatar
un4gvnbb un4gvnbb is offline
almost anything within reason is possible to do to a car. its really just how much you want to spend. if you put enough into it you could give your car gull wings.
Old 11-22-2002, 10:10 AM
that may be true - but from the factory you can open and close the two front windows with the key in the door lock. it is a standard feature of all 02 and up maximas... the key fob will only LOWER the windows. It's the same with the Pathfinder as well as the 02 and newer altimas (depending on trim level).
no need to go spending extra money, because it comes that way from the factory...
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 05:46 AM
'09 Corolla KeyFOB, keyless entry programming Question btrolla Corolla/Matrix/Voltz 1 09-03-2010 01:00 PM
1991 OLDS Cutlass Supreme SL 2-door keyless entry module PAPAJACK Cutlass Series 0 07-31-2010 10:56 PM
94 s10 remote keyless entry programing instructions needed stillblazin Problem Diagnosis 0 07-01-2009 10:39 PM
remote keyless entry problem smity9089 Intrigue 0 04-14-2009 12:45 AM
